Old 05-23-2018, 11:22 AM   #1
Gerald cook
Default Floor boards
I have a question about the hole in the floor board for the battery access. I’m guessing in the past it was to add water to the battery cells? It’s not as important as it use to be can I seal it up with no adverse affects? Jerry
Gerald cook is offline   Reply With Quote
Old 05-23-2018, 11:41 AM   #2
WHN
Default Re: Floor boards
I guess if you have a battery in your car that does not need service, you wouldn’t need the access. If your floorboard has the hole, do you have the metal cover that goes over it?
It takes some time to remove floorboard screws to get at battery. That’s why the battery service opening is there. Enjoy.
WHN is online now   Reply With Quote
Old 05-23-2018, 12:25 PM   #3
Benson
Benson's Avatar
Depending upon where your battery terminal bolts are located with respect to the hole in floor board, it is nice to just flip back the carpet or mat then pull the metal cover and unhook one battery cable without removing the 10 or twelve screws in the lower floor board.
This is really nice if there is an electrical fire and you must unhook battery to stop it!
Every second counts in this situation!!
Do not ask how I know this!
Let me just say that the first thing I did to Coupe in 1962 was repair a small leak in the gas gauge with gas dripping down behind the panel.
The insulation on the wiring was all frayed with wiring exposed ... When I unhooked the speedo / instrument panel and moved it; the fire immediately started.
The gas fire was not too big but the electrical fire was big time bad news!
More smoke than a Huey with an electrical fire inside the cabin.
The second thing after replacing all the wiring was to install a fuse so it would not happen again.
I enlarged the hole in floorboard near the rear battery terminal for just this reason.
In addition sometimes the starter switch sticks and it is nice to turn off the spinning starter in a hurry.
Old 05-23-2018, 12:51 PM   #4
SeaSlugs
SeaSlugs's Avatar
yup - batteries havent changed a whole heck of alot over the years, they still need the water checked and topped off occasionally.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-23-2018, 02:10 PM   #5
slammin
slammin's Avatar
That's the main reason to install a shutoff switch in the battery ground cable.
slammin is offline   Reply With Quote
Old 05-23-2018, 07:08 PM   #6
Dick Steinkamp
Dick Steinkamp's Avatar
Actually most batteries sold today are either sealed, AGM, or gel and require no maintenance. In fact there is no way you could add water if you wanted to.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-23-2018, 07:14 PM   #7
WHN
Are you talking about 6 volt Model A batteries?
I just bought one. Looked around at local auto and tractor supply houses. They all were selling ones needing distilled water and acid.
Got mine at a Tractor Supply.
Old 05-24-2018, 09:17 AM   #8
burner31
burner31's Avatar
Just leave the plate there and call it sealed.
Keith
Shawnee OK
'31 SW 160-B
Old 05-24-2018, 10:17 AM   #9
SeaSlugs
SeaSlugs's Avatar
yup - i haven't seen a normal 6v battery yet that didnt have the water caps.
Even some batteries that looked sealed arent really - they just have big rectangular caps over the fill holes.
Old 05-24-2018, 10:51 AM   #10
Dick Steinkamp
Slug, I don't want to beat this to death, but I was responding to your quote above.
If you were actually referring to batteries that look and fit like the original batteries in our Model As, you are absolutely correct. Although there are maintenance free battery alternatives for our As, most do not look original and may require a different hold down than stock.
Old 05-24-2018, 12:50 PM   #11
Steve Wastler
Steve Wastler's Avatar
6 volt tractor battery’s at tractor supply still twist on caps to add water or acid to top off just bought one 3 weeks ago, $79.00. I prefer this type of serviceable battery better fwiw....
Steve Wastler is offline   Reply With Quote
Old 05-28-2018, 03:34 PM   #12
Galaxiedan
you wouldnt happen to have the part number for that battery?
Galaxiedan is offline   Reply With Quote
