08-28-2016, 09:08 AM | #1 |
Solid driveshaft Questions
We are helping a friend with a 32 roadster project. It's a Brookville body on a repro frame. It has a 46-48 rear end and shortened torque tube ( to fit in the 32 chassis). The driveshaft is the original solid late style shaft now about 49 inches long.
In the original application I know the solid driveshaft needed a carrier bearing about mid point in the torque tube. The question is: Is the solid shaft OK to use in the shortened version WITHOUT the carrier bearing mid point in the torque tube? At the much shorter length I don't think "whipping" would be an issue. Does anyone have any experience with this type of set up? Your comments/thought s would be greatly appreciated. Thanks, Phil
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
08-28-2016, 09:22 AM | #2 |
Re: Solid driveshaft Questions
