Old 02-06-2020, 04:55 PM   #1
shew01
shew01's Avatar
Default “Do not use a file” to dress down breaker points
Page 346 in the Service Bulletins says “If the points are burnt or pitted they should be dressed down with an oil stone. Do not use a file.”
I’ve seen similar references elsewhere for Model As. Why would Ford not want to use a point file?
Old 02-06-2020, 05:06 PM   #2
J Franklin
J Franklin's Avatar
Default Re: “Do not use a file” to dress down breaker points
Maybe the file in the farmers garage was a bit corse compared to a points file or oil stone.
Old 02-06-2020, 05:40 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
It can chip the contacts--- i use a diamond knife sharpener
Old 02-06-2020, 05:53 PM   #4
David R.
I would assume the smoother the surface, the less likely for pitting to begin, hence the reasoning for oilstone instead of file.
David R. is offline   Reply With Quote
Old 02-06-2020, 07:22 PM   #5
shew01
shew01's Avatar
Hmmm... Actually, that sounds plausible. :-)
Old 02-06-2020, 07:25 PM   #6
shew01
shew01's Avatar
The ones I found on Amazon looked too big to use on a car. Can you post a link to what you use?
Old 02-06-2020, 07:27 PM   #7
shew01
shew01's Avatar
Is an oil stone the same thing that some folks call a hone?
Old 02-06-2020, 08:50 PM   #8
Beater
Beater's Avatar
emery paper was the go to in my day
Beater is offline   Reply With Quote
Old 02-06-2020, 11:49 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Yea they meant a standard file. the "modern" points file is more of a burnishing tool.
Old 02-07-2020, 12:54 AM   #10
redmodelt
redmodelt's Avatar
Besides you have a better chance of keeping the contacts parallel using a points file.
Old 02-07-2020, 10:35 AM   #11
Purdy Swoft
Purdy Swoft's Avatar
I use a narrow strip of adhesive type sandpaper that I can fold over , stick together so it sands on both sides , like a file that is flexible . This works best for me .
Old 02-07-2020, 10:48 AM   #12
Badpuppy
Yes. Oiled stone or honing stone.
Old 02-07-2020, 10:49 AM   #13
burner31
burner31's Avatar
I have and still use the same point file I've used for at least the last 50 years, no problems yet.
Keith
Shawnee OK
'31 SW 160-B
Old 02-07-2020, 03:57 PM   #14
PeteVS
PeteVS's Avatar
I was told years ago not to use any kind of abrasive (sand paper etc) because it will leave crap embedded in the contact surfaces. FWIW
Old 02-07-2020, 04:03 PM   #15
emf
emf's Avatar
Not sure I would use emery paper anywhere electrons are flowing. (points, armatures, etc) Emery is conductive and may short out to ground if grit accumulates. Sand paper would be a better choice if a good fine file can't be found...
Frank
emf is offline   Reply With Quote
Old 02-07-2020, 04:25 PM   #16
captndan
captndan's Avatar
If you're stuck out on the road use what eve you have. If you're in town don't be so darn cheap. Go buy a new set.
captndan is offline   Reply With Quote
Old 02-08-2020, 12:07 AM   #17
Aok
Aok's Avatar
My 2 cents I have worked on 40's 50's mopars (Dodge Plymouths) for many years and have got a . Lot of vehicle's running by cleaning the points with a point file. Ok not a Model A but a similar animal.
Aok is offline   Reply With Quote
Old 02-08-2020, 01:13 PM   #18
J Franklin
J Franklin's Avatar
Sometimes the "new" stuff isn't as good as repaired "old" stuff.
Old 02-08-2020, 01:29 PM   #19
redmodelt
redmodelt's Avatar
Filing the points can reach a point of no return! LOL The points on my 48 had been filed so many times in the past that they were down to the base. I finally had to bite the bullet and get new ones. Most of the time you are just removing the deposits from one side anyway, then giving a quick wipe out with a match book cover to get oil off.
Old 02-09-2020, 09:09 AM   #20
Terry, NJ
Terry, NJ's Avatar
I use a diamond, Nail file. I got it in the Dollar store for, you guessed it, 1buck. It's slimmer than a metal file. Emery paper would be fine except Emery is a conductor. I don't want a conductive dust floating around inside the distributor.
Terry
