01-31-2020, 05:13 PM | #21 |
Re: 8cm cam grind
The 1CM cam came about for the change over to the rotator type valves and the automatic transmission.
01-31-2020, 06:47 PM | #22 |
Re: 8cm cam grind
That makes a lot of sense. The automatic transmission would seem to me to require a milder cam for a smoother idle to accommodate idling in gear when stopped. Maybe, maybe not.
01-31-2020, 07:03 PM | #23 |
Re: 8cm cam grind
May I ask if there is a (best) stock cam for the pre 8ba style motors with the front mount dizzy?
01-31-2020, 08:41 PM | #24 |
Re: 8cm cam grind
get the merc cam and cut the gear off mart, piece o cake for you
01-31-2020, 09:15 PM | #25 |
Re: 8cm cam grind
Have the Merc cam ground on an early core.
01-31-2020, 09:35 PM | #26 |
Re: 8cm cam grind
01-31-2020, 09:48 PM | #27 |
Re: 8cm cam grind
In my opinion, yes; the 32-34 steel cam. In 1935 with the introduction of the bigger, heavier bodies, along with cast iron camshafts, Ford 'detuned' the cam timing.
01-31-2020, 10:44 PM | #28 |
Re: 8cm cam grind
Do you have some specs to compare the cams?
01-31-2020, 11:24 PM | #29 |
Re: 8cm cam grind
Only some;
year engine valve lift inches intake opensBTC intake closesABC exhaust opens BBC exhaust closesATC 32-34 V8 85 .292" 9.5 * 54.5* 57.5* 6.5* 35-42 V8 85 .292" 0.0* 44.0* 48.0* 6.0* 46-49 V8 100 .292 0.0* 44.0* 48.0* 6.0* [1949 intake increased to .296" lift]
Unfortunately, two half wits don't make a whole wit! Last edited by Brian; 02-01-2020 at 12:48 AM. |
02-01-2020, 12:14 AM | #30 |
Re: 8cm cam grind
so my 34 motor that they left water in to freeze in not a boat anchor after all!
02-01-2020, 12:32 AM | #31 |
Re: 8cm cam grind
8CM that I degreed when building the 260 Merc:
9* 53* 50* 7* (checked at .014/.015 lash) .330 lift at 0 lash Compares nicely to the 32-34 cam Brian posted above. I think it'd be nice with the front modified for the early engine. An EAB cam is also very close to these numbers when advanced 4 degrees. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
02-01-2020, 06:07 PM | #32 | |
Re: 8cm cam grind
02-01-2020, 06:11 PM | #33 |
Re: 8cm cam grind
02-01-2020, 06:28 PM | #34 |
Re: 8cm cam grind
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
02-01-2020, 10:51 PM | #35 |
Re: 8cm cam grind
02-01-2020, 10:58 PM | #36 |
Re: 8cm cam grind
You can install an 8ba style cam in an early block and front cover. Then you can run a late style distributor. W do this all the time
02-01-2020, 11:03 PM | #37 |
Re: 8cm cam grind
02-03-2020, 07:21 AM | #38 |
Re: 8cm cam grind
