Old 01-24-2020, 01:30 PM   #1
40ford
40ford's Avatar
Default Flathead Engine Type?
Can any flathead experts tell me what type of flathead engine this is and what it might have came out of?The markings on the oil pan and the water pump case have me confused?I was thinking about purchasing for a spare to rebuilt for my 1952 F-1.I was told it is a truck engine??? Thanks
40ford is offline   Reply With Quote
Old 01-24-2020, 01:39 PM   #2
40cpe
40cpe's Avatar
Default Re: Flathead Engine Type?
The water pumps look like Mercury '49-'51. It looks like there is a little green paint on the lower front of the head, so Mercury is my guess. The oil pan doesn't look like it is from a car, though.
Old 01-24-2020, 01:46 PM   #3
40ford
40ford's Avatar
I noticed ford is stamped on the head?
Old 01-24-2020, 01:55 PM   #4
Newc
Newc's Avatar
Yep; Merc pumps with the spacers. Maybe a 4" crank Merc?? Does it turn?? Newc
Newc is online now   Reply With Quote
Old 01-24-2020, 01:59 PM   #5
40ford
40ford's Avatar
Yes,it is suppose to be free!If it is mercury,wouldn't the heads be marked mercury?I have never seen an oil pan like that either?
Old 01-24-2020, 02:05 PM   #6
flatheadmurre
flatheadmurre's Avatar
The later car oilpans has thoose reinforcements...started maybe -51...
Has the later car narrow belt pulleys.
Long breather tube and manifolds look like truck.
Maybe a car/merc engine that has been used in a truck ??
Using fords heads give you higher compression.
And intake was usually swapped to make aircleaner/carb fit.
Old 01-24-2020, 02:15 PM   #7
petehoovie
petehoovie's Avatar
French Flathead?
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 01-24-2020, 04:05 PM   #8
Ol' Ron
Ol' Ron's Avatar
You won't know, till you open it up,
Old 01-24-2020, 04:06 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
French Flathead?
WAGs do nothing but promote more confusion! DD
T5 W/TORQUE TUBE
It's one thing to be ignorant! It's a whole 'nother story when you're proud of it!
Old 01-24-2020, 04:12 PM   #10
rotorwrench
rotorwrench's Avatar
BITSA engine. Bits of this and bits of that. All I can say is that it in the 8BA family. The blocks are all pretty much the same. The center sump is Ford car from 1949 through 53 with variations. 8RT truck manifold with long fill tube. The coolant pumps like those were only used on Mercury cars from 1950 thru 51 if they are marked 0CM. The 49 Merc had a different mount set up but the pumps looked similar. They would be marked 8CM for a 49. The fan is Ford style.
I wouldn't count on it having a Merc crank. It will have to be opened up to find that stuff out and whether it has the early valves or the later rotator valves.
Old 01-24-2020, 08:39 PM   #11
Desoto291Hemi
That is not a 49 Merc front pulley . Could be later maybe.
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 01-24-2020, 08:50 PM   #12
40ford
40ford's Avatar
Owner states now that the heads are marked 8BA on the heads and has a stroke of 3.75 so being a Mercury engine is out!
Old 01-26-2020, 04:22 AM   #13
deuce lover
deuce lover's Avatar
French Flathead?
NO,not French
deuce lover is online now   Reply With Quote
Old 01-26-2020, 08:15 AM   #14
Ol' Ron
Ol' Ron's Avatar
Just remember, a good block is worth it' weight in gold.
Old 01-26-2020, 09:13 AM   #15
Bored&Stroked
Bored&Stroked's Avatar
Yep! I just picked up a good 49-53 block yesterday - had been tanked, magged and the valve work started (then they sold the machine shop). Was happy to get it for $375.
Hoping to pickup two more 49-53 blocks . . . have some 'projects' to get done!
