Old 12-20-2019, 11:54 AM   #1
Mart
Mart's Avatar
Default Flathead Friday. Crusty Flatty Pt8: Bolts, Bores and a Buma!
After last weeks tumbleweed premiere I'm dispensing with that nonsense.
Part 8 of the Crusty Flatty series shows me dealing with two broken bolts, inspecting bores and valve seats, and also a quick look at the boring machine and the cuts made in the test block. Come and join me in the garage for some flathead fun.
Mart.
https://youtu.be/zwb76CUyDoY
Mart is online now   Reply With Quote
Old 12-20-2019, 12:32 PM   #2
done4
done4's Avatar
Send a message via Yahoo to done4
Default Re: Flathead Friday. Crusty Flatty Pt8: Bolts, Bores and a Buma!
Pretty cool Mart, enjoy watching and not having to do it.
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 12-20-2019, 01:15 PM   #3
tubman
tubman's Avatar
Mart,
An interesting video for sure. I found the degraded cast iron to be quite curious.
A couple of remarks; t]1.) The new sound method seems to be working quite well, and 2.) you really need a bigger candle.
Denny
Old 12-20-2019, 01:27 PM   #4
marko39
I had the same broken bolt to remove but only sticking out about a quarter inch. I was able to thread a nut on the stud then welded it. Came right out. Mark
marko39 is offline   Reply With Quote
Old 12-20-2019, 01:35 PM   #5
38bill
38bill's Avatar
Mart how are you indexing the Buma to the bore?
38bill is offline   Reply With Quote
Old 12-20-2019, 02:36 PM   #6
FrankWest
FrankWest's Avatar
Mart, enjoying your work. Interesting boring machine, are machine;s like that made today. Seems portable??? well, usually boring machines are large milling machine types, but then I don't know much about boring machines.
FrankWest is offline   Reply With Quote
Old 12-23-2019, 05:40 PM   #7
Mart
Mart's Avatar
Thanks for the feedback guys.
Denny: The sound is much better, thanks. The candles may be small but I got lots of 'em.
Marko: Yes, the welded on nut method nearly got used this time. I might do a video on the broken studs, that would probably involve welding.
Bill: The Buma has three projecting "catspaw" probes that are wound out using the knob on the top. I have just been finding a part of the bore that seems reasonable and use that to centre it.
Frank. Yes, this is an old school portable boring machine. In theory it could have been used in vehicle but I wouldn't fancy doing that.
I'm new to all of this. I bought the machine some time ago and those bores in that test block are the first ones I have done.
Not sure when I will be able to do any updates, I've been laid low with Labyrinthitis the last few days. It's like being on a ferry boat on a choppy sea. Not pleasant at all.
Mart.
Old 12-23-2019, 07:14 PM   #8
flatford8
flatford8's Avatar
Great video once again Mart!....sorry to hear your not feeling well.....I have a very similar block, cylinder condition an all. I haven’t tried pulling the pistons yet. I believe mine is a pre-war replacement block. It had Edelbrock heads and a Sharp dual intake with Strombergs. 8BA timing cover and drilled lifter bores with adjustable lifters. Unfortunately a couple of the cyl. bores are worse than yours. Good luck with the project and hope your feeling better soon...Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 12-26-2019, 01:44 PM   #9
Mart
Mart's Avatar
Thanks Mark. I am feeling a little better, I'm going to dress up warm and go down the garage and try and tidy up. I was working on the daily when I was taken ill. I left it in quite a mess.
Do you have plans for your motor?
Mart.
Old 12-26-2019, 02:22 PM   #10
mfirth
THANKS Mart ! Fun stuf and times two on what Denny said. Cherrio !
mike
mfirth is offline   Reply With Quote
Old 01-02-2020, 10:47 AM   #11
Terranova
Mart, hoping you feel better!
I have to say, aside from the great flathead footage, the best part of these videos for me, on this side of the pond, is listening to your accent! ����
Please keep up the good work. You’re inspiring me to get out in the garage to work on mine! Thank you!
Also, can you track down a reasonable priced ‘48-‘53 Thames E494C panel van project for me? Thanks!
Terranova is offline   Reply With Quote
