Old 01-14-2013, 07:58 PM   #1
eystein
eystein's Avatar
Default Rear Subframe for Cabriolet
I am considering replacing the rear subframe cross member on my 1930 Cabriolet. (The steel channel structure below the outer panel that ties the wood sills together at the rear of the car)
Does anyone know if this part is being reproduced for the Cabriolet ?
If not, I am considering modifying the part that is sold by Snyders et al for the Coupes and Roadsters. This would involve separating the inner and outer pieces of the crossmember, modifying the inner one and welding the pieces back together.
Does anyone know where Snyders, Brattons etc gets these crossmembers (for the coupes and roadsters). I am considering approaching the manufacturer to see if they would sell me an unassembled crossmember, which would make for less work in modification.
eystein is offline   Reply With Quote
Old 01-15-2013, 09:09 AM   #2
jw hash
jw hash's Avatar
Default Re: Rear Subframe for Cabriolet
no one that I know of reproduces them. if you have yours for a pattern you can modify a coupe or roadster to work.
jw hash is offline   Reply With Quote
Old 01-15-2013, 10:18 AM   #3
Kevin in NJ
It is not reproduced.
The outer part is basically the same as coupe. You will need to countersink the rivet holes for wood screws.
You will need to remove the inner structure and swap it in the coupe/roadster part. The part does not go as wide as the wood sills are wider. Plus the end sticks out longer for the long bolt.
Mine is a coupe outer piece with a reused cabriolet inner piece.
Kevin in NJ is offline   Reply With Quote
Old 01-15-2013, 02:37 PM   #4
PO51
PO51's Avatar
I bought one a couple of years ago for a 68A project,that is still that. Someone on Fordbarn had several made up and was selling his extras, you might post under parts wanted and see what response you get.
PO51 is offline   Reply With Quote
Old 01-15-2013, 06:11 PM   #5
eystein
eystein's Avatar
Called Brookville Roadster Today, and they were happy to supply the roadster part with the inner and outer member separate (not spot welded together) That should make the needed Cabriolet modification a breeze
I'll keep you posted on how things proceed.
Old 02-06-2013, 03:48 AM   #6
eystein
eystein's Avatar
Received the roadster/coupe cross member with inner and outer piece separate last week. The Brookville guys were pleasant to deal with and had no problems in sending the part unassembled.
Old 02-06-2013, 05:42 PM   #7
Russ B
Please post some progress pics when you get further on it. It is good to know Brookville will sell parts that way.
Russ B is offline   Reply With Quote
Thread Tools
Display Modes
