06-23-2018, 07:08 PM | #1 |
Used Parts Engine Area
City:
Cape Cod
State:
MA
Price:
in ad
Connecting rod cores with caps & nuts, $5 each Timing gear cover, front, 1929-31, $5 each Timing gear cover, side, $5 each Intake manifolds, $35 each Intake & Exhaust manifold combo, $65 set Water gooseneck on cylinder head 1928-29, $13 each Water gooseneck on cylinder head, 1930-31, $10 each Main bearing cap cores, $10 each B-6344 Main bearing bolt 4 1/2", $2 each B-6347 Front or Center Main bolt, 6", $2 each Fan, original, no problem evident yet, $15 each Starter Drive 1929-31, $10 each Accelerator linkage, $15 each Crank ratchet nut, good teeth, $5 each20 Oil pan with tray, 1929-31 $20 Oil pump drive gear assembly, MAY need a new gear, $15 New gear for above, for you to install, $20 Generator cutout, $20 |
