06-10-2018, 10:50 AM | #1 |
Cowl Lamp ID needed.
I have two cowl lamp lenses I would like to identify.
Is a flat lens 3 5/8 inch outer edge to outer edge diameter 1932 or what ? Is a raised center lens (convex) 2 3/4 inch outer edge to outer edge diameter 1933-34 or ? Thanks, if my guess is right they will be available to sell. |
06-10-2018, 11:55 AM | #2 |
Re: Cowl Lamp ID needed.
32's are convex also.Model A's are flat
06-13-2018, 12:46 PM | #3 |
Thanks deuce lover. However I still need an ID on the convex lens, 2 3/4 inch diameter which must be 1932 or 1933-34 but which is it? Came from Ford dealers parts room.
06-13-2018, 01:20 PM | #4 |
Most likely 32.33-34's I believe are approx 2.25"
06-13-2018, 01:37 PM | #5 |
The cowl lamps on my '34 measure 3 inches including the bezel. The exposed diameter of the convex glass lens measures 2 1/2 inches. Probably a 1/4 inch of glass under the bezel....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 06-13-2018 at 01:47 PM. |
06-13-2018, 02:53 PM | #6 |
