Old 04-23-2021, 02:00 PM   #1
Orignal36
Orignal36's Avatar
Default Fix it or leave it
I just picked up a 1936 model 68 Fordor sedan. Interior is all there, but rough. Has rot at the front of both rear fenders where they meet running boards and the drivers floor pan/trans cover. This car was in the original owners family its whole life. Runs and drives ok. Engine was replaced with a 51 Merc. Engine replacement makes it not 100% original. Am I ok to fix the rot and replace the interior or should this be left as is? If you agree its ok to fix, who makes a good interior kit?
I will post pictures when I can get to the car. Being stored due to space at my house. I am new to this so will be asking for any help and ideas you can assist me with!
Thanks!
Orignal36 is offline   Reply With Quote
Old 04-23-2021, 02:48 PM   #2
Kube
Kube's Avatar
Default Re: Fix it or leave it
This is a tough question to answer in my opinion as there may be variables involved that I can't understand or haven't been disclosed.
If there is NO emotional attachment to this particular vehicle, I'd say "leave it as it is". That's looking at this from a strictly economic view point.
1936 Fordor sedans do not have much value. As such, you will rapidly exceed the value if you begin repairing rust and swapping interiors.
As you are new to "this", I'd suggest you get your feet wet with this one. Have some fun, keep your investment as low as possible while staying safe on the road and learn some of the proverbial "ins and outs" of owning one of these prewar Fords.
Then, if you like the hobby, sell this one and move on to one that is further along / nicer. In the long run, that's going to be the more economical path.
Old 04-23-2021, 03:10 PM   #3
V8ER
Welcome!
Please post your location. Someone close to you may be able to help you learn about your car.
V8ER is offline   Reply With Quote
Old 04-23-2021, 04:35 PM   #4
19Fordy
19Fordy's Avatar
Kube sure offered some excellent advice. Take it slow and don't let it become a "money pit".
Old 04-23-2021, 04:43 PM   #5
VeryTangled
VeryTangled's Avatar
Welcome Orignal36!
If I was the owner I'd begin with is the frame safe.
Then I'd look at tires, brakes and steering.
Then I'd move to how it runs over the road? Cooling? Tracking?
-Jeff H
Old 04-23-2021, 08:41 PM   #6
Blastfromthepast
If you can do the repairs yourself I would fix the fenders with replacement patches from a company called EMS and find a replacement trans cover here on the forum. As far as the interior goes that’s something to think about. Interiors are pricey and some companies are no longer in business which mean kits are scarce. You would probably have to bring it to your local interior shop. I would cover The seats with some sort of temporary covering and drive the car like that.
Blastfromthepast is offline   Reply With Quote
Old 04-24-2021, 03:38 AM   #7
FortyNiner
FortyNiner's Avatar
How do you want to use this car?
Old 04-24-2021, 05:57 AM   #8
Orignal36
Orignal36's Avatar
Thank you all for your guidance. I want to be able to drive this car to cruise nights and leisurely drives in the fall to watch the leafs change (happy wife, happy life). Depending on how reliable I find it, maybe drive it up into New Hampshire so the original owners family can see her once again. I have all service records for this car going back into the 40's! She has about 80% of her original Washington Blue paint. The other 20% has faded into history! I know if the engine was not changed she would be considered a survivor and I should not change anything, but this is not the case.
The frame and tires are excellent, brakes are so so, as is the steering. Problem with the steering goes back to when they changed the engine. They left the Merc oil pan on which causes the steering to make contact with the oil pan. I have sourced the correct oil pan but need to find the pick up tube. This is my first dealings with mechanical brakes so I have some learning to do! She goes down the road straight, runs at 150 degrees.
Please do not get me wrong, I do have some mechanical experience. I have been an FAA certified airframe and powerplant mechanic for over 30 years. My welding is mediocre but if I take my time I can bring that up to speed. I do want to patch the fenders and floor to keep things from getting worse. As for the interior, I have no experience here but figured with a kit I would be able to follow directions.
Thanks again for the guidance, have anything else for me?
Old 04-24-2021, 07:15 AM   #9
marko39
i would check to see if you have thermostats installed and they are working correctly.
marko39 is offline   Reply With Quote
Old 04-24-2021, 07:48 AM   #10
corvette8n
corvette8n's Avatar
Drive it, enjoy it, fix the little things during the winter.
corvette8n is online now   Reply With Quote
Old 04-24-2021, 09:53 AM   #11
VeryTangled
Hi Everyone. Good info Orignal36 on your intentions. (BTW there's a bit of an aviation undercurrent here too.)
When you start thinking about brakes, have a read through this thread... It's sorta long, but there is almost everything you need to think about with mechanical brakes in there somewhere. You can find parts vendors that have real original Ford essentials here on the 'Barn too. It won't take you long to find out which ones have earned stellar reputations.
https://www.fordbarn.com/forum/showthread.php?t=289449
Marko caught a good thing you said. Running down the road at 150 degrees is considered a bit cool.
Re-reading, I saw cruise nights. Your wiring is likely sketchy. If it was never replaced it's copper with a cloth sheath and the sheath deteriorates creating shorts and voltage drops. Luckily they are a piece of cake to rewire (new wires are copper, rubber, cloth) and looms, clips, etc are available. Michael Driskell is one of the vendors who will listen to your proposed project and suggest required bits you didn't anticipate needing. Michael's telephone is on the website: https://thirdgenauto.com As I said other very fine vendors have what you'll need too.
This thread needs a photo. Eventually you may want to post some, here's some hints.
https://www.fordbarn.com/forum/showthread.php?p=1863427
-Jeff H
Old 04-25-2021, 08:47 PM   #12
Tinker
Tinker's Avatar
If you just bought it. Drive it for a season or two, fix mechanics if needed.
If you are quick and have time to get to projects quickly, that might be a different thing. But it can be a bummer to have a car out of service on a nice day.
Get some osho or another rust convertor and treat the rust. It'll slow it down. I have a couple small spots (quarter/half dollar) with exposed sheet metal (not rust through) that I treated with osho. It still hasn't rusted after 3 yrs.
Best of luck!
Old 04-25-2021, 08:55 PM   #13
Holeshot
This is sound advice. ^^^
Too many times I have seen a driving car taking apart for upgrades/etc. and quickly the costs spiral out of control and it turns into a long term project car that unfortunately never gets back on the road.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 04-25-2021, 09:03 PM   #14
Tinker
Tinker's Avatar
Hey the fordor and the sedan isn't quite the "eye" sore of yester-year. Restoring or driving one would be refreshing, i'd stop at a show and look at it. Besides someone needs to have and restore them, otherwise all the period new movies will be filled with coupes with radials.
Old 04-25-2021, 10:48 PM   #15
GB SISSON
GB SISSON's Avatar
This sage advice reminds me of the ferro-cement sailboat guys in the sixties/early seventies. 50' hull framed with rebar, stretch on the chicken wire. Gunnite swimming pool guys spray on the goop, bust out the trowel. 50' sailboat for 8 grand. Now comes the sails, spars, rigging, interior, diesel auxillary, bronze hardware. None of which are cheap. OK, I'm getting off topic. Like all the smart guys here say, get it SAFE, enjoy it and work as you go. They don't have to be expensive to have some really good. clean fun. And where are those pictures?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 04-25-2021, 11:16 PM   #16
cas3
The death of many old cars has been the guy that was gonna restore it. Took it apart, killed it, sometimes push it out in the yard for a couple decades all the while its not for sale...until its junk. Some of the best cars today are the ones that made it thru that untouched to live again
Old 04-26-2021, 12:33 AM   #17
Alex Mcknz
Have it fix, I believe that there's always a solution to every problem. At the end of the day, it will be worth it, especially when you're driving it. That is when all your hard work paid off.
Alex Mcknz is offline   Reply With Quote
Old 04-26-2021, 07:11 AM   #18
Frank Miller
Frank Miller's Avatar
How is the roof on it? How bad is the interior? VT posted a brake thread and my first task would be to get those working as new. Second is the oil pan to fix the steering issue. Check the rest of the chassis including the shocks and spring shackle bushings.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 04-28-2021, 01:41 PM   #19
Orignal36
Orignal36's Avatar
Thanks again to all that provided guidance. Here she is! Probably not worthy to be shown in the company of cars like VeryTangled posted, but shes mine!! Right now I have some family medical issues so she will have to sit and wait another month or two before I can start tinkering with her. Believe me, all your suggestions will be looked at and followed when I can. Was not sure how to post picture so I just pasted one.
Old 04-28-2021, 02:05 PM   #20
BigGameJames
Hello all,
New member here.
Looking forward to learning a lot from you all.
BigGameJames is offline   Reply With Quote
