07-10-2019, 05:30 AM | #1 |
Trailer Dimensions
I am planning on trailering my father's 1931 Model A Cabriolet and would like to use an enclosed trailer. Does anyone know what dimension trailer I might need?
Thanks |
07-10-2019, 07:30 AM | #2 |
Re: Trailer Dimensions
I use a 16' which give me a little room to get around for the tie down and some supplies. A 14' would work but is starting to get a little tight. Now this would be for a pickup or coupe. A 2 or 4 door sedan will require more length. I'd suggest trying the trailer out if possible. Take your vehicle and see if they will let you drive it into the trailer.
07-10-2019, 08:20 AM | #3 |
I use a 16 for my roadster and Town sedan. Plenty of room, with a trunk. The car is only 13 foot.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
07-10-2019, 10:38 AM | #4 |
I have what the manufacturer calls a 18', but that is the rectangular floor space area. It has a V-nose so that space is added. It has a work bench and plenty of room to haul or store stuff in. As whirnot says, 13' is Model A car length, pickups may be longer.
07-10-2019, 12:43 PM | #5 |
07-11-2019, 02:30 PM | #6 |
