Old 06-08-2018, 08:29 AM   #1
Joop
Joop's Avatar
Default Tool indentification
Looks like a honing tool but????
Like to know what this tool is used for.
B D Ballantine Mfr.
Fitchburg, Mass.
Pat Applied.
Joop is offline   Reply With Quote
Old 06-08-2018, 09:34 AM   #2
Corley
Default Re: Tool indentification
Hard to imagine the size of those puppies, maybe stick a ruler in one of your pix.
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 06-08-2018, 12:29 PM   #3
briphaeton
Maybe valve grinding gauges,
briphaeton is offline   Reply With Quote
Old 06-08-2018, 02:50 PM   #4
mdsbob
Looks like it could possible be a specific purpose made holder for dial indicators for performing shaft alignment using the reverse dial method.
mdsbob is offline   Reply With Quote
Old 06-09-2018, 07:52 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Since I can't figger it out, I "probably" don't NEED it!---"IGNORANCE IS BLISS"--Whatever thet MEANS???
Bill Simpleton
"THE ASSISTANT GURU OF STUFF"
Old 06-09-2018, 08:44 AM   #6
briphaeton
Definitely valve grinding gage. for determining the valve length for engine with non adjustable lifters. The top is adjustable with a lock screw (note the 45 degree angle like a valve), once you get a measurement you set the bottom one to grind a valve the the correct size.
Old 06-09-2018, 02:27 PM   #7
KR500
KR500's Avatar
briphaeton has it correct. you place your valve in the fixture bump the bottom edge to your valve, transfer this to the drop in dummy valve and on your valve grinder set the dummy against the stem grinding wheel( wheel stopped) and dial back the clearance on the valve grinder.
KR500 is offline   Reply With Quote
Old 06-09-2018, 05:10 PM   #8
Russ/40
Russ/40's Avatar
Yup, that's it. A low tech version of the micrometer version, that will work with mushroom stem valves.
Russ/40 is offline   Reply With Quote
Old 06-10-2018, 07:53 AM   #9
Corley
Bill Simpleton
But now you know what it's for, so now you need it! Good news, another new tool on the shelf! But wait, do you need a Sioux valve grinding machine to go with it? Yes, I think so, and those are big. Got one to sell you though...
Corley
Old 06-10-2018, 10:48 AM   #10
briphaeton
I plan on making them.
Old 06-12-2018, 01:38 PM   #11
Joop
Joop's Avatar
I think we are trailing away from the question.
Thanks for pointing me in the right direction.
If someone is interested in this tool please contact me.
Thanks
Old 06-12-2018, 11:48 PM   #12
California Travieso
Send a message via Yahoo to California Travieso
Thanks
Hey Joop,
That never happens on the Barn!
David Serrano
California Travieso is offline   Reply With Quote
Old 06-13-2018, 07:55 AM   #13
SeaSlugs
SeaSlugs's Avatar
Thanks
Nooo we dont do that here. might wanna stick a tag and label them as such on them.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Thread Tools
Display Modes
