06-27-2021, 01:45 PM | #1 |
1947 Super Deluxe ignition Switch
Trying to diagnose an intermittent non start. Definitely a spark issue. I think the ignition switch may be bad. Removed it and having trouble opening it as I wanted to clean inside connections. Would replace it but all I find available is outer body with terminals. Anywhere I can get whole switch??
06-27-2021, 02:52 PM | #2 |
Re: 1947 Super Deluxe ignition Switch
Check eBay, e.g., https://www.ebay.com/itm/17271948615...sAAOSwo0JWOqKB
06-27-2021, 03:33 PM | #3 | |
06-27-2021, 03:52 PM | #4 |
You are correct, Lawson.
06-27-2021, 05:10 PM | #5 |
Yes Lawson. I’m not looking for the key/cylinder. Square switch connects to toggle.
06-27-2021, 10:24 PM | #6 |
06-27-2021, 10:45 PM | #7 |
Thank you. Wasn’t obvious how to open it. I’ll drill out the mounting holes and open up and clean. Apparently you can’t get the whole unit anywhere.
06-28-2021, 01:59 AM | #8 |
06-28-2021, 09:05 AM | #9 |
I did the same as fordor41, on my '46 Coupe, except I soldered the "ears" on the outer edges, just enough to hold the case together. Make sure the lever and switch are in the correct position to mate, when you bolt the switch back on, as the pin from the lever has to mate into the hole in the back of the switch. Otherwise, the switch could get damaged.
06-29-2021, 02:46 PM | #10 |
The lever type ignition switch in the '47 commonly wears a groove in the bakelite in the back of the switch preventing the dimples in the internal arm from making contact. The parts are available from C&G (800-266-0470) Part# 81A-3704. If you need to replace the wiper arm, 81A-3704/9K (kit). The lever type switch was phased out in early '47. It had been a Ford item since '32 in one form or another.
07-01-2021, 04:46 AM | #11 |
Opened the switch and cleaned all contacts. Re installed. Getting about 5.4 volts at coil with key on so apparently switch is functioning. Still no start. Seems like no spark. Resistance test on coil gives me 0.6 and 8400 ohms. Will have to get a helper to do spark test at plugs. Will very intermittently fire. Maybe points and condenser.
07-01-2021, 01:22 PM | #12 |
Well it seems I found the issue. Hi tension coil wire seems to have been spliced between coil and where it enters boot to connect to plug wires. I will replace it but wondering how the non coil end is removed from that rubber boot.
