06-29-2019, 11:07 PM | #1 |
Distributer rebuild
A while back I came across someone on here that rebuilds the old Ford V8 distributes. Any suggestions? Or do I just clean up what I have and go with it? Of course I would put in new points& condenser.
Sent from my LM-G710VM using Tapatalk |
06-30-2019, 12:29 AM | #2 |
Re: Distributer rebuild
Guess it depends on your experience and dizzy you working with. Always best to have access to the right tools to dial it in.
06-30-2019, 12:33 AM | #3 | |
06-30-2019, 12:44 AM | #4 | |
Helps to know what dizzy you are talking about. Not to be rude... but this makes little to no sense to me. If you go to your sent messages it'll show whom you sent it to. Less you deleted it. But you would have to know to go to sent messages to check. But are you asking where should I have it worked on? or if you can rebuild it? |
06-30-2019, 12:57 AM | #5 |
There are two guys I know of on here that do this; "BUBBAS IGNITION" and "Charlie NY". At the present time, I believe that Bubba is not taking on any new work due to health problems. You didn't mention the type of distributor ("helmet", "crab", "rabbit ear", or "Load-a-Matic") which may make a difference. Also, I believe "Skip" in Florida may do some of this type of work.
You should at least specify the type of distributor. |
06-30-2019, 01:01 AM | #6 | |
06-30-2019, 01:11 AM | #7 |
what I pm'ed you earlier. But for everyone.
https://www.fordbarn.com/forum/showt...vy+distributor http://www.bubbasignition.com/loadam...lacements.html . Last edited by Tinker; 06-30-2019 at 01:21 AM. |
06-30-2019, 01:28 AM | #8 | |
06-30-2019, 02:22 AM | #9 |
Looks like a cool project. Look forward to your updates and pictures here.
06-30-2019, 03:05 PM | #10 |
Cliff Green, listed in V8 Times, did a great job of restoring my distributers. His phone # is 703-346-1458
06-30-2019, 04:44 PM | #11 |
Find a shop with a distributor machine. That will allow exact setting of the dwell, check of the advance, and whether the bushings and shaft are in suitable condition. Many shops no longer have a machine. so check around your area. At our shop we keep our Sun machine busy. Many shops have never seen or worked on a contact point distributor since they were replaced by electronic systems.
07-01-2019, 04:02 PM | #12 |
You might want to check with Skip in Punta Gorda ,Fla. He is the go to guy for me.
07-02-2019, 11:15 AM | #13 |
Third Generation Automotive in Tennessee ( Michael Driskell) is very good at rebuilding EFV-8 distributors.
07-03-2019, 02:03 AM | #14 |
Thanks everyone for the feedback. Charlie ny was recommended here and reached out to me so I am sending it off to him. Hopefully he does me well.
07-03-2019, 06:59 PM | #15 |
msstring, I have a lot of work from CharlieNY on my '36. Trans, rear, carbs, dizzys, fuel pumps. All of it top notch. You've made a good choice.
I can also second JM 35's shout out of Michael Driskell, he's 35fordtn here on the 'Barn. I've got one of his 11a helmet units, and a fuel pump from him on my 35.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
