Old 09-10-2013, 10:02 AM   #1
demax33
Default 33/34 fiberglass fender braces?
Ok building a 33/34 fiberglass car and wanting to know what to use as front fender braces and also are there two braces on each front fender? Will braces for a steel fender work due to the glass thickness? Thanks for any help..Keith
demax33 is offline   Reply With Quote
Old 09-10-2013, 12:02 PM   #2
TJ
TJ's Avatar
Default Re: 33/34 fiberglass fender braces?
The steel braces are your only option. You may have to slightly modify them to fit the glass fenders, but it depends on the fender.
Old 09-10-2013, 12:19 PM   #3
bobH
I'd say THREE braces per front fender. I guess it depends on how you count them.
1. The 'big' brace at the front, also supports h/l stand.
2. Short 'rod' brace at front, goes from frame top, to the 'big' brace.
3. Rear brace from frame to skirt area on fender.
bobH is offline   Reply With Quote
Old 09-10-2013, 01:29 PM   #4
demax33
Thanks for the info...I'll be ordering up a set and giving them a try..thanks again
Thread Tools
Display Modes
