Old 09-09-2013, 03:25 PM   #1
jstrez5
Default windshield crank
need help taking out a windshield crank on my 1939 ford deluxe, I need to know if i would need to take the dash out in order to get the old crank out. I am having trouble with getting the gear that protrudes through the dash, does anyone know if there is an easier way of getting the crank without taking the dash apart. Reason being the gears in my old crank have broken off.
Thanks
Jim S
jstrez5 is offline   Reply With Quote
Old 09-09-2013, 06:11 PM   #2
jstrez5
Default Re: windshield crank
problem solved had to take part of dash apart to get old windshield regulator out.
Old 09-09-2013, 08:00 PM   #3
36-5window
I just took my 1939 ford coupe windshield crank out, I am rebuilding it so I had the dash out. I broke one screw off that goes into the windseild frame, so I ground off the 2 pins that hold the arms to the windshield. I got it out that way , so now I can try to get the screws out without breaking any more. It was very rusted.
1939 Ford 5-window Deluxe Coupe
36-5window is offline   Reply With Quote
Old 09-09-2013, 08:29 PM   #4
40cpe
40cpe's Avatar
Are there parts available to rebuild them? It seems that most you find have stripped or very thin gears.
40cpe is offline   Reply With Quote
Old 09-09-2013, 11:07 PM   #5
swoopNZ
MEMBER EMERITUS
There were 2 types of gears.
Cast and steel.
The cast ones seem to get stripped more easily.
You see repair kits for them ( the cast ones ) on e-bay sometimes
swoopNZ is offline   Reply With Quote
