Old 11-18-2020, 11:20 AM   #1
19Fordy
19Fordy's Avatar
Default Crestliner steering Wheel Question
Is it true that Ford used the Kaiser Frazer letter "F" in it's design of the 1949-50 Crestliner steering wheel horn button logo?
Old 11-18-2020, 11:41 AM   #2
scicala
scicala's Avatar
Default Re: Crestliner steering Wheel Question
Good question. If I had to guess I would say if it looks like the Frazer "F", then probably just a coincidence and not intended. Also, the Crestliner was made in '50 and '51. Not in '49.
Sal
scicala is offline   Reply With Quote
Old 11-18-2020, 11:25 PM   #3
fordor41
fordor41's Avatar
ford used their own font. Now it's called "fordscript"
fordor41 is offline   Reply With Quote
Old 11-19-2020, 01:35 AM   #4
mercman from oz
mercman from oz's Avatar
Those Crestliner Steering Wheels with the stylised F look great.
Old 11-19-2020, 03:12 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
I found that the "Darrins" ONLY seemed to use that unique "K", as in the first two pictures.
Darrins below!
Some "Frazers", depending on year, had a different "K" above the company's Bison logo, while the later ones had a gorgeous "Starburst K".....below! I even found a couple more oddities for earlier years. Not ALL Kaiser wheels were white. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-19-2020, 03:27 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
C'mon Man! You have enough invested in that thing that you should be able to show it off bigly. Sure is purdy! DD
T5 W/TORQUE TUBE
Old 11-19-2020, 08:53 AM   #7
19Fordy
19Fordy's Avatar
Thanks V8.
"Bigly is betterly".
Old 11-19-2020, 10:23 AM   #8
Automotive Stud
Automotive Stud's Avatar
I've heard that too, probably only on this board. I've never seen a Kaiser/Fraiser use that F logo.
Automotive Stud is offline   Reply With Quote
Old 11-19-2020, 10:37 AM   #9
TJ
TJ's Avatar
Logos were probably trademarked, so they could not be used by anyone else.
Old 11-19-2020, 05:39 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Jim's (19Fordy) Crestliner-type wheel is the only place that I have ever seen the "F" in that font. DD
T5 W/TORQUE TUBE
Old 11-19-2020, 10:51 PM   #11
19Fordy
19Fordy's Avatar
Yes V8. I might be incorrect.
Old 11-20-2020, 07:47 AM   #12
tubman
tubman's Avatar
I have heard this story for a long time (probably at least 30 years ago for the first time). Ever since then, whenever I see a Frazer, I check the steering wheel. I have never seen a wheel like this on a Frazer.
Old 11-20-2020, 06:24 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Actually, there MAY be a little confusion as to just what a "Kaiser-Frazer" was. Henry J. Kaiser and Joseph M. Frazer began building both Kaisers and Frazers in 1947. They appeared to be very similar in appearance to each other. But Kaisers were FRONT-wheel drive, whereas Frazers were REAR-wheel drive. Only 10,000 Frazers were produced in '51 before Joe Frazer went on down the road to bigger and better things. The company then became The Kaiser Motor Corp. and produced Kaisers through the '55 model year. As an aside, a little over 400 Kaiser Darrins were produced, becoming America's FIRST fiberglass sports car, preceding Corvette production by about a month in 1953. DD
A '47 Frazer Manhattan Wheel
T5 W/TORQUE TUBE
Old 11-20-2020, 06:26 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Oopsie...!
T5 W/TORQUE TUBE
Old 11-20-2020, 07:46 PM   #15
tubman
tubman's Avatar
Yeah. Initially, Kaisers were supposed to be front wheel drive; that never happened.
