09-30-2020, 09:13 PM | #1 |
"Poly" brake lines...
I've done a few brake lines (flared and bent) in steel. Next project I wound up using copper nickel which I much prefer. I don't even want to think about working with stainless. But our local parts house has "poly" lines. They're kind of an ugly dark green color but the guys who work there don't seem to know much about them. Can anyone explain them to me? Thanks!!
Don't never get rid of nuthin! |
09-30-2020, 10:03 PM | #2 |
Re: "Poly" brake lines...
I never heard of the poly brake lines. Hope that someone will chime in and let us know
about them. |
09-30-2020, 11:50 PM | #3 |
I've used them, and I didn't think they were any different except maybe the finish on them.
10-01-2020, 04:58 AM | #4 |
The "Poly" part is just a plastic coating that is applied to help prevent corrosion due to road salt etc.
Otherwise the tube has the same form-ability characteristics as copper-nickel tube.
10-01-2020, 06:24 AM | #5 |
i dont understand plastic coating on copper nickel. i thought copper nickel didnt get corrosion. Paul
10-01-2020, 06:39 AM | #6 |
10-01-2020, 06:42 AM | #7 |
Next time I go to get something, I'll take a magnet to see it it's just coated steel and I'll report back.
10-01-2020, 07:07 AM | #8 |
Where did you get the idea that copper-nickel brake line is poly-coated??
10-01-2020, 08:33 AM | #9 |
Goggle it
Underneath the PVF-coating is a double-wall, low carbon steel, copper brazed tubing which meets all international and U.S. requirements for brake tubing. The difference being that Poly-Armour offers 30 times the corrosion resistance of galvanized steel alone.
Henry Ford designed the flathead without the aid of a computer. |
10-01-2020, 09:42 AM | #10 |
It's standard steel brake pipe with a thin green plastic skin on it. I think it may have been (or might still be) OEM fitment for some manufacturers.
Mart. |
10-01-2020, 09:50 AM | #11 |
10-01-2020, 05:04 PM | #12 | |
This is correct.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
10-02-2020, 07:05 AM | #13 |
i used a piece to repair a fuel rail on my truck. I used silicone bronze with a TIG to connect it so I'm guessing they are steel. Finish sanded off but seemd to be on there good.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
10-02-2020, 07:16 AM | #14 |
I replaced my rear lines on a daily driver after they rusted out. After about 5 or 6 years they looked like pretzel sticks.
