Old 12-13-2012, 07:49 PM   #1
corn boy
corn boy's Avatar
Default bell housing for flathead to T-5 transmission
This is the truck "hogshead", stamped steel bellhousing, and starter plate.
3 pieces total. All in very good shape.
If you wanting to bolt a Chevy T-5 transmission behind a 8BA flathead this is most of the stuff you need.
If you read further down, a couple folks wrote about the Dwight Bond adapter plate that you need as well.
Pretty darn sure this is the correct starter plate. The pic makes it look angled but it isn't.
SOLD IT.
Last edited by corn boy; 12-17-2012 at 01:24 PM. Reason: added info, sold the parts.
corn boy is offline   Reply With Quote
Old 12-13-2012, 08:39 PM   #2
hardtimes
hardtimes's Avatar
Default Re: bell housing for flathead to T-5 transmission
corn boy,
Hello! Are you aware of the 'swap' section of this forum? Might get better results there as it is the correct place for sale/trade/wanted items,eh! Good luck.
Old 12-13-2012, 09:49 PM   #3
V8 Bob
V8 Bob's Avatar
Originally Posted by hardtimes View Post
corn boy,
Also, your starter plate is wrong, as it's angled, and ONLY goes with the '49-'51 Ford car stampted steel bell.
Old 12-14-2012, 09:50 AM   #4
George/Maine
George/Maine's Avatar
I have a 53 f100 3 speed flathead has like say 55 trans.
Can this bellhousing be used to go with t5 trans,and what may have to be done to use it.
George/Maine is offline   Reply With Quote
Old 12-14-2012, 08:50 PM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
i've used that style hogs head a few times. It' the cheapest way to hook a T-5 to an older flathead. Dwight Bond make an aluminum adapter, it's only about one inch thick, bolts right to the back of the hogs head, 6 bolts, and the T-5 bolts right to the adapter, It come with a sleeve to go over the T-5 front bearing retainer for the old Ford thro out bearing to ride on. It also has a piece that screws on the side of the adapter for the older clutch and brake pedle to slide over. I think it's about $180.00 Someone on here has Dwights tel no. Walt
Old 12-27-2012, 09:46 PM   #6
bluepanel
I have a 53 F-100 and an 88 S-10 T-5 trans that I picked up at a yard, fresh from the truck. I talked to a man at Wilcap this afternoon. He told me I may be able to use their adapter for the Y block, as the bell for the 53 is different than the 52, but same as the 54 Y block. I will measure the height of my cast bell (with the motor mount ears) and the S-10 bell. They are very close in height. The Wilcap adapter is 1/2" thick. They also sell a longer pilot bearing, if needed, and a custom bearing retainer with bearing for input. The stock Ford throwout rides without need of a sleeve, as adapted. So I am hopefull, may wait til weather warms. I may try a local clutch shop to adapt the 1" 14 spline hub to Ford 10".
bluepanel is offline   Reply With Quote
Old 12-14-2012, 02:36 PM   #7
rotorwrench
rotorwrench's Avatar
I'm sure the Ford Car type bellhousings from 49 to 53 can be used with a different adapter but most folks use the Hogs Head unit so they can still use the rotating equalizer type clutch release shaft with the old style fork. With this in mind, it just depends on what type of clutch actuation system works for your application.
Old 12-14-2012, 02:57 PM   #8
V8 Bob
V8 Bob's Avatar
The F-100 Lt. duty 3-speeds (not sure about the HD 3 speed) used the same B/W T-10 4-bolt pattern as the '49-'53 Ford cars, so any adaptor that fits them should work on your truck, as long as the inputs are the same length.
The one exception is the '51 Mercury full cast bell with the '40-'48 clutch cross shaft.
Old 12-14-2012, 03:31 PM   #9
tiquer
The input shafts are different lengths . I believe the truck one being the longer of the two.The input shaft in the mustang T-5 is the right length but needs the s10 tail shaft housing swap done. the bottom two bolt holes line up also. The top two require some modes done to the truck bell.
tiquer is offline   Reply With Quote
Old 12-14-2012, 08:25 PM   #10
Ol' Ron
Ol' Ron's Avatar
made an adapter for a Mustang T-5 to bolt to a 49-53 ford and it should be 11/16 thick and the pilot shaft front bearing retainers are a different dia.
Ol' Ron is online now   Reply With Quote
Old 12-14-2012, 08:48 PM   #11
296 V8
A GM trans will not bolt to that .. go back to school
296 V8 is offline   Reply With Quote
Old 12-14-2012, 10:59 PM   #12
tiquer
We are only saying the rear tailshaft housing will bolt to the mustang T-5, not the S-10 trans to the bell housing?
Old 12-14-2012, 10:53 PM   #13
tiquer
The truck bell has the rear engine mount ears also. If you used the steel 49-50 car bell the rear mounts could be an easier mod than trying to wield on the cast truck bell to change the top bolt pattern. Not saying that wielding cast can`t be done just that steel would be easier?? And Ron`s adapter sounds very cool.
Old 12-15-2012, 08:53 AM   #14
296 V8
150.oo bucks plus shipping.
Please PM me if you are interested.
I was speaking to this
Old 09-30-2013, 11:02 PM   #15
Rigley
I am interested....tell me more.
Thanks
Jim
Rigley is offline   Reply With Quote
Old 12-15-2012, 09:51 AM   #16
rotorwrench
Everyone that has used the truck back bell uses an adapter that is made to work with it. It is a commonly used part and is still a relatively inexpensive way to go if a person wants to put a T5 behind a flathead ford V8
http://www.wilcap.com/flathead.html
Old 12-15-2012, 10:50 AM   #17
Ol' Ron
Ol' Ron's Avatar
Any idea what the adapter cost for a 49-53 Ford passenger car to Ford T-5?? This is probably the easiest swap.
Old 12-15-2012, 11:38 AM   #18
Richard in Florida
Richard in Florida's Avatar
Any idea what the adapter costs for a 49-53 Ford passenger car to Ford T-5?? This is probably the easiest swap.
Oh boy, is it ever! Using the simple adapter plate Ol' Ron's talking about (he made one for me) and any T5 with a Ford bolt pattern and input shaft, you can...
Use the stock flywheel
Use the stock pressure plate
Use the stock pilot bearing or bushing
Use the stock throwout bearing
Use the stock clutch linkage
Adapt the stock rear mount (at least I did)
Get a speedometer cable for $12 at AutoZone
All you have to buy are a clutch disk and a speedometer drive gear!
Richard in Florida is offline   Reply With Quote
Old 12-15-2012, 01:46 PM   #19
hope
hope's Avatar
Just asking: I have a Ford T-5 i was saving in case my "kid blew" the one out of his Mustang a few years ago. How elaborate would it be to adapt to a 59 A block?
hope is offline   Reply With Quote
Old 12-15-2012, 03:51 PM   #20
Richard in Florida
Sorry, can't help you there. I've only done it with an 8BA.
