Old 09-30-2021, 07:09 PM   #1
Ed in Maine
Default 32 Model B Slow Starting after storage, Solved
After having my car in storage over the winter months, it was difficult to get started. This year, I didn't get back to the car until this month. This year I checked over the distributer and checked the spark plug gaps. Then I got the idea to turn over the car for about 30 seconds with the plugs out. The engine turns very fast with the starter. Sure enough, with everything back together, and the gas pumped to the carburetor, the car started immediately. Such a simple solution to the slow starting problem. Ed
Old 09-30-2021, 07:11 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 32 Model B Slow Starting after storage, Solved
What was fixed?
Old 09-30-2021, 07:19 PM   #3
Phil Gillespie
Phil Gillespie's Avatar
Originally Posted by J Franklin View Post
What was fixed?
My guess would be, spinning over with plugs out allowed fuel to be pulled through quickly and carb body full. Then with plugs refitted away it went??
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-04-2021, 10:58 AM   #4
Ed in Maine
You are correct Phil. Sorry I didn't make that clear. Ed
Old 10-04-2021, 11:11 AM   #5
rockfla
rockfla's Avatar
PLUS, getting oil circulated back into the nooks and crannies without a whole lot of friction on the moving pieces does it good and helps it too!!!!
