Old 12-02-2016, 01:22 PM   #1
Paul/Woodinville
Paul/Woodinville's Avatar
Default Removing steering wheel
I have a large crack at the base of the steering wheel which I'm going to try to repair. I have a the puller and I have taken the horn ring off. I know the bolt holes to attach the puller are 5/16 but I'm not sure if it's fine or course thread. Also the wire for the horn that comes up the shaft can that be pulled down from the bottom somewhere so that the end of the puller will fit into the shaft. I'm working on a 49. Thanks in advance.
Paul/Woodinville is offline   Reply With Quote
Old 12-02-2016, 01:30 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Removing steering wheel
Paul
You do not need to pull the wheel to repair it. Use files and sandpaper to Vee out the crack, be sure to clean the metal that is exposed , and I have had success with JB Weld.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 12-02-2016, 03:29 PM   #3
Frank Miller
Frank Miller's Avatar
There is a wire you unplug at the bottom of the steering box and the wire pulls out with the horn ring. While you can repair the wheel in the car i think having it out will make it easier. I believe the hole are fine thread.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 12-02-2016, 04:54 PM   #4
54vicky
54vicky's Avatar
if you opt to remove the wheel.to make it easier to feed wire back through shaft.I would tie a piece of string on to the wire on box end before pulling wire it will ease the putting the wire back through.
54vicky is offline   Reply With Quote
