Old 10-01-2018, 11:56 PM   #1
wkuehnis
wkuehnis's Avatar
Question Front windshield rubber for closed car
Hi,
I made my first trip with my A through 8 countries in 8 days and made 2500 km.
Sometimes it was very cold. I have a hot air heater on the collector.
It works: it blows nice hot air into the car, but from the front windshield comes much more cold air, so it's very could inside.
It's a Briggs fordor 1931.
Question:
What kind of rubber or gasket can I mount on my front widshield to insulate it a bit against the wind. (best would be a order number from one of the distributers)
Do I have to clue it ?
I try to add some pictures from the windshield.
Thanks for help
Willi
wkuehnis is offline   Reply With Quote
Old 10-02-2018, 12:04 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Front windshield rubber for closed car
From snydersantiqueauto.com
Windshield frame gasket part # A-79500
Windshield hinge gasket Part # A-79550
The gasket around the window fits in a metal gutter that is part of the frame
The top gasket fits between the windshield frame and the header.
Old 10-02-2018, 12:59 AM   #3
wkuehnis
wkuehnis's Avatar
Thanks,
yes, I have seen them in the catalog, but till now I don't see how to fix them. Maybe it will be clearer, if I hold the rubbers in my hand.
So I don't need to order anything else to mount and fix them ?
Thanks
Willi
Old 10-02-2018, 02:19 AM   #4
J Franklin
J Franklin's Avatar
Maybe someone can post a photo of the rubber installed, If I have time I will try to get a photo. Does your windshield have any remnants of old rubber gasket?
Old 10-02-2018, 06:54 AM   #5
desotoguy
I suggest that you inspect the top rubber gasket very closely before you remove the WS. I recently attempted to replace this gasket on my coupe and found the replacement was not formed to the correct shape, and when installed made the WS fit incorrectly. Most likely the air is entering the cab on the botton and sides of the WS.
desotoguy is offline   Reply With Quote
Old 10-02-2018, 07:16 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
No glue is needed. The rubber seals should slide into metal channels, and I'm sure someone will have pictures to post.
Old 10-02-2018, 07:30 AM   #7
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Here is a picture of how the top gasket is mounted to the header. But I agree this gasket is not likely the issue. It's going to be the gasket around the windshield frame sides and bottom.
MickeyT is offline   Reply With Quote
Old 10-02-2018, 07:43 AM   #8
Brian SATX
Brian SATX's Avatar
Desoto- not sure what car you have, but a flat windshield and a slant windshield do have different top gaskets. Not all suppliers carry teh one for the slant. Make sure you get the right one.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 10-02-2018, 11:23 PM   #9
Ed Wendell
Ed Wendell's Avatar
Willi,
The gaskets slide in a channel. You will want to clean the channels, and clean them again. I used Ru-glide (a rubber lubricant) to make them slide better. Tire shops use it when mounting tires. The channels may be crimped in a couple of places to hold the gasket in place. I used a screw driver to pry them open a little bit. You will need to miter the 2 bottom corners, so don't get ahead of yourself and cut the gasket off to soon.
Good luck,
Ed
Ed Wendell is offline   Reply With Quote
Old 10-02-2018, 11:33 PM   #10
wkuehnis
wkuehnis's Avatar
Hi,
thanks for your answers. I didn't realize the rubbers at the top till now.
But the cold wind came only from the buttom, so I first want to solve the problem there.
Till now, I don't understand, if I have to mount this rubber on the fix frame part or on the movable windshield. But I guess, it's not on the movable windshield, because there is now "channel" to mount it.
Willi
Old 10-03-2018, 12:27 AM   #11
J Franklin
J Franklin's Avatar
The windshield frame gasket rubber goes on the movable frame with glass. Maybe the channel has rusted away or is not being recognized.
Old 10-03-2018, 06:07 AM   #12
MickeyT
I'm about to mount mine as soon as the windshield glass comes in. Here are a couple of pictures of the replacement gasket and the frame.
Old 10-03-2018, 07:41 AM   #13
wkuehnis
wkuehnis's Avatar
Thanks,
now it's clearer where the rubbers belongs. But I don't have this channels to fix them.
Maybe I can mount the rubbers with silicone ?
But: Maybe there have different styles for this frames ?
Willi
Old 10-03-2018, 08:19 AM   #14
100IH
Might be that the only way to replace rubber is to remove the entire assembly. If you can see that the thin, bendable metal retainer strip is no longer there to hold the rubber, May be a foam rubber strip with an adhesive on the back will work. Will be difficult to find another glass frame as there are some variables and they tend to rust away.
100IH is offline   Reply With Quote
Old 10-03-2018, 11:12 AM   #15
J Franklin
J Franklin's Avatar
Maybe some thin sheet metal and a tig welder could fabricate a new channel. Or use rubber weatherstrip as noted above.
Old 12-24-2018, 09:12 AM   #16
Paragon
I'd like to know how you install the windshield weatherstrip around the side of the windshield frame where the square nuts (one on each side) are located in the bead channel? Do you notch the bead? Do you stretch the bead around the nuts w/o any cutting? What do you use to glue the mitered corners together?
Paragon is offline   Reply With Quote
Old 12-24-2018, 09:37 AM   #17
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
I used a small amount of super glue to glue the mitered corners together. That stuff works surprisingly well on rubber.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
