Old 01-28-2019, 05:49 AM   #1
flathead48
Default Wiring diagram
Does anyone know who would have a wiring diagram for 1956 Mercury Montclair 4 way power seat. Thanks
flathead48 is offline   Reply With Quote
Old 01-28-2019, 12:00 PM   #2
fordrodsteven
fordrodsteven's Avatar
Default Re: Wiring diagram
I'm not very knowledgeable regarding the differences between Ford and Mercury. I should think the wiring would be very similar. Maybe use a diagram for a full size ford or even a Thunderbird. This is a copy of a diagram from one of my old Thunderbird Parts Digest books. The 4 way selectomatic is different. This diagram is for the regular four way power seat for Thunderbirds 1955 through 1957. I assume the full size fords are the same so it might also carry into Mercury. If the wire color codes on your car are the same I would think that this diagram would be correct for your application.
Or..... If your car has the selectomatic type switch I can supply that wiring diagram from my Thunderbird book.
fordrodsteven is offline   Reply With Quote
