09-14-2019, 09:01 AM | #1 |
Where to get a OD solenoid for a '49 convertible?
Anyone know of a place one could be found? Mine is not working right at all.
Fifth Ave Garage in Kansas sells new ones but states the standard one he has will not work on the convertible or the station wagon. The standard one has a 1 inch pawl and the convert. takes a 1 -1/2 inch pawl. You would think someone would have one??? Any help would be helpful...... |
09-14-2019, 10:18 AM | #2 |
Re: Where to get a OD solenoid for a '49 convertible?
Mac Van Pelt, Old Ford Store in San Dimas, Shoe Box Central, or maybe Joe at Joe's Antique Auto might know of a source if he didn't or couldn't get one.
09-14-2019, 11:39 AM | #3 |
There is a place in Punta Gorda, Fl. that sells the parts called Hydro electric. G.M.
www.fordcollector.com |
09-14-2019, 12:11 PM | #4 |
JT I sent you a PM. Gary
09-14-2019, 12:12 PM | #5 |
We get then at NAPA. Good quality usually much less expensive than vendors.
09-16-2019, 07:32 AM | #6 |
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-16-2019, 11:22 AM | #7 |
It's the operating shaft that moves the pawl. The convertibles had a rather unique way of operating the OD due to the beefed up cross member being in the way. They used a rocker mechanism to function the pawl and it was mounted to a plate that is located under the transmission. It may be possible to use a good shaft from a convertible solenoid in one of the new solenoid bodies. The length of throw of the operating shaft is the only difference. Modifying the length of a regular short type may also be a choice.
This site has an illustration about the second or third illustration down the list. https://www.fordmercassociation.com/...erchandise.htm |
09-16-2019, 01:00 PM | #8 |
There is a good explanation, with pictures of the adapter used on the convertible and station wagons with x frame as well as the rotation of the flat spot on the solenoid in the Early Ford v8 Club 49-50-51 Restoration Guide . Chapter 4 page 4-6.
Changing the rotation of the flat spot on the solenoid to 5 degree from the standard 35 degree angle is easy to accomplish. Hope this helps, Tom Fynan |
09-18-2019, 10:37 AM | #9 |
Thanks to Gary Duff he was able to solve my problem!
09-19-2019, 06:51 AM | #10 |
Glad you got it fixed. Inquiring minds would like to know the solution for future reference.
09-19-2019, 08:26 AM | #11 |
Frank
Well said. The resolution of a problem is a learning experience for all. Tom |
09-19-2019, 12:58 PM | #12 |
Gary Duff just happened to have a couple of Solenoids NOS for the convertibles and stations wagons. He offered to sell me one of them.
After much digging I now know a lot more about these solenoids. Both the regular one and the one for convertibles and station wagons with the off-set mounting have the one inch pawl. BUT the difference is the flats on the pawl are different. There are 30 degrees difference. The drain hole in the case is in a difference place also. After I get the new one installed am going to see if I can re-index my old one. I believe it is possible? The lower half of the case can be used and the drain hole will be correct. If this works out I will post the success or failure........the old wives tale going around that the convertible has a longer pawl is NOT correct for the Ford OD,s. I believe those with 1-1/2 length are for Lincolns?? |
09-19-2019, 05:03 PM | #13 |
Nothing worse than old fart memories. Do this, do that, but none of them ever did it.
Had two converts, cut a notch in the cross member so the regular od transmission would fit. No problem. Purists want that crappy crazy (expensive) goofy linkage for the underslung solenoid. Good luck. Been there. |
09-20-2019, 08:21 AM | #14 |
JT
As I stated in reply 8, You can rotate the pawl on any solenoid to adjust the flats. Weep hole might not be on the bottom. That is what I did years ago on my 49 convertible, never had a problem. Frank Miller was very helpful when I installed my OD. Tom Tom |
09-21-2019, 10:41 AM | #15 |
The operating rod length maybe different for the T85 R11 or possibly the older design transmission on the Lincolns. It's good to know that it is a matter of the degree of offset for the operating rod tip. I had previously thought it was length so that's one thing to note for future reference. Thanks for the info.
I'll have to do some research on this since 5th Avenue IG has the convertibles and station wagons listed as 1.5 ". If this is incorrect, then they need to change the information. Last edited by rotorwrench; 09-21-2019 at 10:47 AM. |
09-21-2019, 03:13 PM | #16 | |
