06-05-2017, 03:32 AM | #21 |
Re: 1937 Ford p/u rad support/ grill support question
Hi here are the pictures as promised. Don't take any notice of the shiny aluminium box under the hood this is what I made to stop the distributor getting wet.
06-05-2017, 03:38 AM | #22 |
Picture 4 shows a little bracket that fixes to the radiator and prevents the grill spreading when the hood is clamped shut.
06-05-2017, 11:16 AM | #23 |
Kiwi tony. Wow those are great pics. Thanks for going above and beyond to get me those. I can see I've a few parts to hunt for. Looks like I see a fender support I wasn't aware of either. Thank you!!!
Sent from my SM-N910W8 using Tapatalk |
06-05-2017, 04:52 PM | #24 |
I am also restoring a 37 1/2 ton. I have the original radiator from mine which needs a new core and haven't been able to find a radiator shop within a reasonable distance to do the work. I bought a new radiator from Brassworks which is about 95% correct. Let me know i f you want pictures.
06-05-2017, 06:52 PM | #25 | |
06-08-2017, 01:57 AM | #26 |
06-21-2017, 10:20 PM | #27 | |
Also, I think I see a brace that I cant make out for sure. Looks tubular and maybe bracing the fender??? If that makes sense can you tell me what I am seeing? It's the picture where you are looking down into the engine compartment on the passenger side. |
06-23-2017, 02:11 AM | #28 |
no the brace is almost flat, it bolts to the front fender bracket and stops it flexing.
