Old 11-02-2016, 05:48 PM   #1
krzewinskibe
krzewinskibe's Avatar
Default Need thoughts...what color is this?
Working on my 1929 Tudor and trying to figure out exactly what color it originally was.
it was repainted some god awful blue at some point in its life, but I found the original color under the carpet which I think should be lower body color. I *think* its Bonnie Grey, however according to the model A Ford Paint and Finish Guide, they ceased using that color in April 1929. This car's serial number (matching frame and engine) indicate an Oct 1929 car.
The corresponding upper body color for Bonnie Grey is supposed to be Chelsea Blue which is very greenish per the paint and finish guide.
Below are pics of the cross brace, an area I sanded in the lower body and what appears to be OEM upper body colors in areas that I sanded on the upper back and the belt.
Can anyone confirm this? Especially since it appears to contradict what is in the paint and finish guide.
Thanks!
floor cross brace:
Here is a section of the lower body I sanded through the blue and some other areas where the blue repaint peeled:
Here is the upper back sand through:
And the belt
1929 Tudor
krzewinskibe is offline   Reply With Quote
Old 11-02-2016, 06:02 PM   #2
krzewinskibe
Default Re: Need thoughts...what color is this?
According to the book, after April 1929 used the following lower/upper color combos:
vagabond green/rock moss green
rose beige/seal brown
andalusite blue/black
mountain brown/thorne brown
thorne brown/black
none of those make sense with the evidence.
1929 Tudor
Old 11-02-2016, 06:11 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I bought some original purchase orders from a dealership in New York, and a couple have colors listed that were supposed to have been dropped half a year earlier.
Old 11-02-2016, 06:13 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Krze,
Sounds as though you are doing a High Points car, if so, my HAT'S OFF to you!
Bill Semioriginal
"THE ASSISTANT GURU OF STUFF"
Old 11-02-2016, 06:16 PM   #5
krzewinskibe
Originally Posted by BILL WILLIAMSON View Post
Krze,
Bill Semioriginal
nah...not high points...but looking to take it as close as I can within reason.
1929 Tudor
Old 11-03-2016, 04:30 PM   #6
Stew Masche
Stew Masche's Avatar
Any trace of original paint under the gas tank? If so, polish it a little, and compare to the refinish guide. Found the original color this way on a 29 Tudor that had been brush painted black many times.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 11-03-2016, 07:45 PM   #7
Barber31
Barber31's Avatar
Krzwinskie, if you're curious to see what you color combination looks like, there is a 29 Tudor listed on the Austin, Texas craigslist. It has the same combo as yours but doesn't give the name of the colors. Maybe you could contact them to ask if they know the month it was built and if it was original colors.
Barber31 is offline   Reply With Quote
Old 11-03-2016, 08:08 PM   #8
wrndln
The body crossmember in the first picture looks like Bonnie Gray. I painted my 29 phaeton Bonnie Gray and it looks the same. The secondary color used with Bonnie Gray is Chelsea Blue and used on the raised areas.
Rusty Nelson
Old 11-04-2016, 12:07 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Did you send copies the standards committee?
Old 11-04-2016, 12:21 AM   #10
Mike V. Florida
Look here;
http://www.autocolorlibrary.com/acl_files/ford1929.html
Old 11-04-2016, 05:05 AM   #11
Tom Wesenberg
No, but they were posted on Fordbarn and Marco and others saw them.
Old 11-04-2016, 09:14 AM   #12
pgerhardt
pgerhardt's Avatar
My 29 Tudor is also an April car and the body and belt colors look like vagabond and rock moss green to me. Here are some pictures of mine so you can see what it would look like if you go with those colors.
pgerhardt is offline   Reply With Quote
Old 11-04-2016, 10:09 PM   #13
BILL WILLIAMSON
On race cars, GREEN used to be considered BAD LUCK!
Bill Blue
Old 11-05-2016, 08:53 AM   #14
mshmodela
mshmodela's Avatar
BEAUTIFUL Color and car!
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 11-05-2016, 10:51 AM   #15
pgerhardt
pgerhardt's Avatar
Bill Blue
"British Racing Green"?
File Type: jpg Screen Shot 2016-11-05 at 11.50.53 AM.jpg (59.4 KB, 13 views)
Old 11-05-2016, 11:04 AM   #16
ian Simpson
Bill Blue
Except for British Racing Green.
Whoops - too late
ian Simpson is offline   Reply With Quote
Old 11-05-2016, 01:30 PM   #17
Gary Karr
Gary Karr's Avatar
krzewinskibe, I agree with Rusty in that it looks like Bonnie Gray to me. Here is a picture of my early Feb '29 Tudor in those colors.
Gary Karr is offline   Reply With Quote
Old 11-05-2016, 03:07 PM   #18
hazelhoff
Looks like the car was stripped to the bare metal. Then reprayed. Floor part looks like gunmetal ble
hazelhoff is offline   Reply With Quote
Old 11-05-2016, 03:29 PM   #19
pgerhardt
pgerhardt's Avatar
I did some work in Photoshop to compare the colors. The body color (cross member) could be Bonnie Gray (but is a little too blue). but the belt line color is definitely Rock Moss Green. If you could sand a bit more of the body preserving the green. Then just before taking another picture, wipe the area with a damp cloth. that would give us something more to work with.
File Type: jpg Screen Shot 2016-11-05 at 4.19.02 PM.jpg (29.8 KB, 35 views)
Old 11-06-2016, 08:24 AM   #20
hazelhoff
Guys be real !
This is supposed to be a late '29. Check the body date stamp ! My guess is the engine was replaced.....
Henk
