Old 11-14-2017, 01:32 PM   #1
W1964
Default Need Source for engine part common to 35-48
I need an Adapter (fuel pump mounting) pn 48 9415. It is mounted on the rear of the intake manifold. The fuel pump is attached to it and the oil filler/breather cap is on top. It's illustration is on page 214 of the "green book" and the pn is shown on page 420. Can you point me in the right direction? Thanks a lot. Bill
W1964 is offline   Reply With Quote
Old 11-14-2017, 01:57 PM   #2
Kube
Kube's Avatar
Default Re: Need Source for engine part common to 35-48
Bill, These are all over places like eBay. I think Drake makes them as well.
Old 11-14-2017, 02:35 PM   #3
supereal
supereal's Avatar
Be aware that the fuel pump push rod must match the stand. The main difference is whether the intake manifold is cast iron or aluminum. Aluminum type is 7.87", and the iron is 8.87", and are not interchangeable.
supereal is offline   Reply With Quote
Old 11-14-2017, 03:16 PM   #4
W1964
Is the only difference the length of the rod?
Thank you.
Old 11-14-2017, 04:05 PM   #5
Kube
Kube's Avatar
Thank you.
Just to clarify - the stands are the same height. The intake manifold makes the difference in which rod is required. As stated in the previous post, the factory aluminum intake requires the (1") shorter rod than the cast iron intake.
Old 11-14-2017, 05:23 PM   #6
Terry,OH
Terry,OH's Avatar
If your looking for 48-9415 as it was produced in 35 it is not reproduced. Ford changed the part appearance and did not change the part number. The later part is available as a reproduction and many originals are for sale on auction sites and retailers. The originals are a much heavier die cast without an embossed ring above the area where the fuel pump mounts as in the photo below.
Old 11-14-2017, 06:31 PM   #7
Mac VP
Mac VP's Avatar
We have good used originals in stock if you don’t find one out there
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
