02-29-2020, 06:46 PM | #1 |
flathead fuel pump push rod
first startup of my rebuilt 8ba ...i had to gravity feed the fuel...the push rod does not move up at all.its as though the lobe is not on the cam...brand new isky 77b....can the cam bearing be insalled as to block the rod ?
02-29-2020, 06:56 PM | #2 |
Re: flathead fuel pump push rod
Maybe the large hole in the rear bearing is not lined up with the bushing above it. I found this out as I disassembled mine for rebuild.
The previous owner did a rebuild and when he couldn't put the rod down, he must have just knocked it down and it bent the edge of the bearing into the gap between the two rear journals. It worked but I had a hard time pulling the cam out for my rebuild. You may be able to look down thru the bushing and see the problem? Terry Last edited by Overkill-F1; 02-29-2020 at 07:03 PM. |
02-29-2020, 07:01 PM | #3 |
thanks... its somthing along that line of thinking... hate to have to pull it apart .the motor sounds so good ..maybe i can get to the bearing from the rear cam cover?
02-29-2020, 07:07 PM | #4 |
All you will be able to do is tap the bearing further inwards with another bearing as a punch, not rotate it or pull it out.
Terry |
02-29-2020, 07:14 PM | #5 |
well that sucks ... what you are saying makes a lot of sense as to the problem ...you have me on the right track... will have to look into it and let you know how it turns out...thank you for the help
02-29-2020, 08:12 PM | #6 |
02-29-2020, 08:15 PM | #7 |
There is always an electric fuel pump.
02-29-2020, 08:19 PM | #8 |
02-29-2020, 09:36 PM | #9 | |
I would place something solid over the old bearing to spread the force of the tapping. If it was mine I would try this before removing the cam, lifters, etc. because you would still have to pull trans, flywheel and rear cover. Terry |
02-29-2020, 09:42 PM | #10 |
We may be getting the cart before the horse here. Need to determine what the problem actual is first. It is most likely the cam bearing being in the wrong position, but that needs to be verified.
02-29-2020, 10:00 PM | #11 |
it has been verified ,,the bearing is to far foward by about a 10th of an inch
02-29-2020, 11:05 PM | #12 |
Time for electric fuel pump.
02-29-2020, 11:20 PM | #13 |
Does the rod go in but is a tight fit?
03-01-2020, 12:02 AM | #14 |
03-01-2020, 02:48 AM | #15 |
03-01-2020, 06:10 AM | #16 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-01-2020 at 07:10 AM. |
03-01-2020, 06:53 AM | #17 |
i think so , i can see the edge of the bearing .it wont allow the rod to drop down contact the cam lobe ..
03-01-2020, 06:58 AM | #18 |
03-01-2020, 10:17 AM | #19 |
I know I posted earlier but this seems like the type of problem that will only get worse if you try to enlarge or move the cam bearing without disassembly.
03-01-2020, 10:38 AM | #20 |
i think i got it ...i ground down an extra rod and worked it in and around ...the bearing was just over lapping about a10th inch...the good rod fits and hits the lobe and goes up and down ...going back together now .. find out soon...thanks all
