Old 12-04-2014, 05:57 PM   #1
oldsman41
Default 50 51 pickups
I really like the looks of the grille on the 51 ford pickup but have a chance to buy a 50 from a buddy real cheap. can I put the fenders and front grille from a 51 on the 50 cab? bolt right up or a lot of fab? thanks and give some comments also maybe im all wet here.
oldsman41 is offline   Reply With Quote
Old 12-04-2014, 06:14 PM   #2
49fordv8f4
49fordv8f4's Avatar
Default Re: 50 51 pickups
The whole assembly will bolt on a '50 cab. I believe the inner fenders are the same, but the hood and outer fender pieces are different between '50 and '51.
Mark
49fordv8f4 is offline   Reply With Quote
Old 12-04-2014, 08:23 PM   #3
oldsman41
yes that is what I needed to know is if would all bolt up without mods and look right.
Old 12-04-2014, 08:48 PM   #4
Barry-ct
Barry-ct's Avatar
It will fit. This was done a lot years ago when the 48-50 fenders went obsolete from Ford and the junkyard stock was getting scarce. I've parted out a couple that were done this way. No real modifications are needed. You even swap just the hoods between early and late as long as you switch the latch plate parts also.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 12-04-2014, 09:37 PM   #5
oldsman41
thanks barry and 49 ford.
Old 12-04-2014, 09:53 PM   #6
VeryTangled
VeryTangled's Avatar
Compare
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
