Old 03-30-2020, 11:55 AM   #1
jcpack
Default 41 ford parts
Have complete running gear for 41 ford car. Engine is complete. Turns over no visible cracks. What is it worth. Part it out? Jim
Note: engine has been sold but I can't seem to delete this message.
jcpack is offline   Reply With Quote
Old 03-30-2020, 12:14 PM   #2
tubman
tubman's Avatar
Default Re: 41 ford parts
God Bless the StreetRodders. The gift that keeps on giving.
Old 03-30-2020, 12:34 PM   #3
corvette8n
corvette8n's Avatar
You didn't say what part of the country your from, that can have some bearing on price. I've seen complete 221 engines going from $100-500. You can't be sure it has no cracks unless it come apart and someone magafluxs it. If your patient it can be parted out. Tranny on a '41 is not worth much <$100, most people want '39 trannys or use T5 replacements. Hope this helps.
Old 03-30-2020, 12:42 PM   #4
19Fordy
19Fordy's Avatar
$100 if you can't see it and hear it running.
Old 03-30-2020, 06:20 PM   #5
Ggmac
What's your location ?
Old 03-30-2020, 06:40 PM   #6
edhd58
edhd58's Avatar
what engine is it 8 or 6??
edhd58 is offline   Reply With Quote
Old 03-30-2020, 06:59 PM   #7
drolston
drolston's Avatar
Rebuild of a '40 - '48 side shift transmission is $400+, and plenty of folks are driving stock three-on-the-tree. A good used one should be worth maybe half that. First pull the bottom drain plug and check what drains out for metal chips. Stick your finger in the hole and feel around. If it passes that test, pull the side cover off and check the gears for wear and chips. If it shows signs of excessive wear or chipped teeth, the <$100 figure applies for the remaining good case and shafts.
