05-07-2010, 09:22 AM | #1 |
1931 RE-stamped firewalls...
Can someone explain the 1931 restamped firewalls to me.
Do show cars have these? Which gastanks were they designed for? Thanks. Pluck |
05-07-2010, 10:12 AM | #2 |
Re: 1931 RE-stamped firewalls...
Congratulations to Steve for the first actual Model A related post!!!
1929 Tudor since 1962 Feather River A's |
05-07-2010, 01:02 PM | #3 |
The 1931 restamped firewalls were flat 1930 firewalls that Ford had left over when they went to the indented firewall.
You will occasionally see an indented firewall that has the flat firewall raised bead smooshed in the indented area. These restamped firewalls were originally intended to be used with gas tanks with cabin side shut off valve, but after restamping them with the indention, they will be used with the tanks that have the fuel shut off valve in the engine compartment. Ford was just using up existing materials before switching over to the ones designed to be indented.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
05-07-2010, 03:53 PM | #4 |
Restamped firewalls are accepted for fine point.
05-25-2010, 09:16 PM | #5 |
Here are a couple of shots of the firewall of my Dad's sedan -- you can easily see the "plug" welded in to fill the old hole for the gas line and the flattening of the ribs
05-25-2010, 10:05 PM | #6 |
Steve, please PM me for contact info, I have two early '29's with firewall dates etc. that I want to discuss with you |
05-26-2010, 07:54 AM | #7 |
Steve Barb Birt`s show phone truck has a restamped fire wall and they had even put the holes in it for the data plate, the judges at last years NWR in cottage grove dock it points for having the holes in it. I have pictures of it but I don`t know how to post them here but I can send them to you. John
05-26-2010, 08:23 AM | #8 |
I found a picture of my restamped firewall on my '31 Town Sedan. The reproduction patent plate was installed in the same 4 holes that the original was in.
05-26-2010, 10:27 AM | #9 |
My restamped firewall is on a late 31 (Sept 1931 engine #) truck which further enforces the the fact that trucks got the left overs. Assuming the truck was actually assembled in Nov or Dec 31 (it had the Dec. version of the engine pans) they must have had a lot of early restamped firewalls laying around late in the year. Seems 5000 of them would have been used up long before the end of 31. Barb Birt
05-26-2010, 10:34 AM | #10 |
OK now i am couious... How can you tell if if is Re Stamped. What are the tell tale signs. Here is my firewall picture?
Mark
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
05-26-2010, 12:22 PM | #11 |
There are excellent photos already posted showing the traces of the flat firewall ribs.
http://www.abarnyard.com/ |
05-26-2010, 12:28 PM | #12 |
Ok thank and i see now the photos and ribs... Mine is NOT a restamp
