Old 01-30-2020, 12:55 PM   #1
burner31
burner31's Avatar
Default Garage heat
It's mid 30's here, in the 20's in my garage...I'm freezing
How do you keep your garage warm?
Keith
Shawnee OK
'31 SW 160-B
Old 01-30-2020, 01:19 PM   #2
Steve Plucker
Default Re: Garage heat
Wood stove
Pluck
Old 01-30-2020, 01:24 PM   #3
RB_Nielsen
RB_Nielsen's Avatar
oil-filled space/radiator heaters
RB_Nielsen is offline   Reply With Quote
Old 01-30-2020, 01:31 PM   #4
kenparker
kenparker's Avatar
60,000 btu nat gas fired furnace suspended from the 10 ft ceiling. It is 40 degrees outside this morning and 73 degrees in the shop. i am a happy camper today. ken
kenparker is offline   Reply With Quote
Old 01-30-2020, 01:32 PM   #5
rfitzpatrick
Move to South Florida??
rfitzpatrick is offline   Reply With Quote
Old 01-30-2020, 01:42 PM   #6
Flathead
Flathead's Avatar
I wait till spring then go like hell before it's winter again.
Flathead is offline   Reply With Quote
Old 01-30-2020, 01:53 PM   #7
Bob/AZ
Bob/AZ's Avatar
Ponderosa Pine chucked into my wood stove. Heats me several times... when I cut it, load it, split it, stack it and burn it.
Bob/AZ is offline   Reply With Quote
Old 01-30-2020, 02:41 PM   #8
Ted Duke
The old potbellied wood stove from my youth.
The one that was used everyday from fall until spring. The kitchen range only when it got cold and the big red monster in the living room only on Saturday nights and some Sundays.
Ted Duke is offline   Reply With Quote
Old 01-30-2020, 02:59 PM   #9
rocket1
100,000 btu gas heater,direct vent through the wall,toasty!
rocket1 is offline   Reply With Quote
Old 01-30-2020, 03:13 PM   #10
Werner
Werner's Avatar
Hi,
I use infrared heater and warm air.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-30-2020, 04:13 PM   #11
Synchro909
Synchro909's Avatar
Heat in the garage is why I won't be doing anything today. It will be in the low 40s and likely more in the workshop so I'll stay where I can breathe. BTW, low 40s is about 110F.
Heat in the garage! I'm happy to share.
It'll be another shocker for the fires which are still burning. It's been over 3 months now. GIVE US A BREAK!
Old 01-30-2020, 04:18 PM   #12
Corley
Mini split heat pump. Works great!
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 01-30-2020, 04:47 PM   #13
oldforder
oldforder's Avatar
All electric house, so have a 220 volt 5000 watt electric heater.
oldforder is offline   Reply With Quote
Old 01-30-2020, 04:53 PM   #14
gary678*
Well insulated garage, portable kerosene heater... does the job in New York's Hudson Valley.
gary678* is offline   Reply With Quote
Old 01-30-2020, 04:59 PM   #15
77Birdman
2020-01-30_04-51-05 by Kerry Grubb, on Flickr
2020-01-30_04-52-46 by Kerry Grubb, on Flickr
I have this in my garage. Propane. Been in place for 3 years now and I havent got to getting it hooked up. I never think about it until winter, then the gas guy gets too busy to do the job. I have an old oil burner that I took out of my house and was thinking about putting that in my large shop. Maybe i'll have heat in both places next winter.
77Birdman is offline   Reply With Quote
Old 01-30-2020, 05:46 PM   #16
Chris Haynes
Chris Haynes's Avatar
Open flame heat in a building full of gas fumes? Sounds scary to me. My new garage is going to have radiant heat in the floor. My current garage is well insulated and warms up nicely from the florescent lighting.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-30-2020, 06:07 PM   #17
Dean Lemoine
Dean Lemoine's Avatar
I’m in north Georgia. So far our winter has been pretty mild. My garage/workshop is in the “walk out” basement of our house. A wall mounted propane heater keeps it very comfortable.
Dean Lemoine is offline   Reply With Quote
Old 01-30-2020, 06:20 PM   #18
George Miller
George Miller's Avatar
I use a air conditioner, heat pump in the garage wall. It works great in sumer or winter.
George Miller is offline   Reply With Quote
Old 01-30-2020, 07:18 PM   #19
leo
leo's Avatar
Hey burner31, I live in New Jersey so our winters are long and cold like yours. When this house was built I put in two 10 foot electric baseboards in the garage and when it's 30 degrees outside I can be comfortable at 60-65 in the garage, but I have to be proactive about my garage time and give the place a chance to warm up for a few hours before it gets cozy. I like the electric heat because it's does not require me to burn something or deal with the ignition problem of solvents if I was burning something for heat. Yes the electric meter spins when I turn on the heat but wood pellets and kerosene cost money too and then there is the maintenance issue.
leo is offline   Reply With Quote
Old 01-30-2020, 08:06 PM   #20
whirnot
whirnot's Avatar
Me too!
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
