10-17-2011, 04:28 PM | #1 |
Banjo Axel tube grease fittings
What do the Banjo rear end axel tube grease fittings grease it does not appear to go directly to the outer bearings when looking at a rear end although when you look at the parts drawing it appears that way.
10-17-2011, 05:28 PM | #2 |
Re: Banjo Axel tube grease fittings
I anwsered my own question by looking further up the axel tube and I see how the grease seal blocks the oil from the diff and prevents grease from going the other way
10-17-2011, 08:03 PM | #3 |
Popular opinion is don't grease them, just pack them plug the fitting. I gave mine a single squirt every spring and had hubs off this year for leaky cylinders and there was no grease blowby in the catchers as is feared.
10-17-2011, 08:45 PM | #4 |
is there a recomended grease?
10-18-2011, 04:39 AM | #5 |
I got a can of "Wheel bearing grease for drum brakes" at NAPA.
10-19-2011, 12:56 AM | #6 |
10-19-2011, 01:43 AM | #7 |
I asked the tech help line at caltex,they said it was a special grease because of the long rollers, normal grease get squeezed out he said.
I would check around,you must have an oil company tech help line there. Lawrie |
