Old 07-08-2012, 06:26 PM   #1
40Dave
Default Fuel Tank
This may seem like a stupid question, but I'm going to ask it anyawy. Should gas flow freely from the tank of my forty pickup when I disconnect the fuel line close to it? (8 to 10") I've had reocurring fuel problems and noticed that there was little or no fuel flow from the tank while installing an electric fuel. Any input would be appreciated. Dave
40Dave is offline   Reply With Quote
Old 07-08-2012, 07:21 PM   #2
Human Fly
Human Fly's Avatar
Default Re: Fuel Tank
Yes, and if not there is no air getting into the tank. Check your vent.
Human Fly is offline   Reply With Quote
Old 07-08-2012, 07:46 PM   #3
George/Maine
George/Maine's Avatar
If you have a full tank gas could come out if stock tank
.I put my electric pump up inside frame about behind wheel.
The line that goes in tank should go in about 4 "
George/Maine is offline   Reply With Quote
Old 07-08-2012, 07:53 PM   #4
19Fordy
19Fordy's Avatar
The pump should be as close to the tank as possible.
Old 07-08-2012, 08:23 PM   #5
Bob G/Spanaway
Bob G/Spanaway's Avatar
If the fuel level is below the fitting on the tank it won't flow.
If above it will.
Bob G/Spanaway is offline   Reply With Quote
Old 07-09-2012, 09:36 AM   #6
19Fordy
19Fordy's Avatar
40Dave, There may be a build up of crud, etc around the gas tank fitting that is preventing sufficient flow of gas at the fuel line exit. After you remove the line clean out the opening and see if flow improves.
Old 07-13-2012, 04:40 PM   #7
40Dave
Great Information! Thanks Guys
Thread Tools
Display Modes
