06-24-2018, 10:05 PM | #1 |
Remove Clutch Pedal Snap Ring
Need to replace the pedal bushings but that snap ring on the end of the pedal shaft is a bear. Regular snap ring pliers have no place to grab.
Searched the threads and do not want to go the cold chisel route. Anybody have a trick to get them off without destroying something? |
06-24-2018, 10:08 PM | #2 |
Re: Remove Clutch Pedal Snap Ring
You should be able to work one side off first with some screwdrivers, picks, and patience. Maybe look up and order a repo replacement first. depending on your patience or if it snaps.
06-25-2018, 09:23 AM | #3 |
Use 2 small flat blade screw drivers. One to apply upward pressure to hold snap ring in place, the other to gently pry up and expand the snap ring. I think they are fairly easy to bend without breaking.
06-25-2018, 11:51 AM | #4 | |
They are not reproduced so don't lose them
06-25-2018, 01:32 PM | #5 |
I have those nos
06-25-2018, 02:02 PM | #6 |
06-25-2018, 02:09 PM | #7 |
It's amazing, the huge number of "UNOBTANIUM" NOS parts that Fred (barnfind08) has laying-around in multiple buildings. Some of you guys like Kube for instance, should be stocking-up on some items like this. Fred has some really rare stuff. DD
06-25-2018, 02:27 PM | #8 |
You know, I can't remember getting that thing off. But lying on my back in a great big hurry for my first test drive, I couldn't get it back on! Gave up and twisted wire around it. This is a good reminder to check it..........I got a car lift now!
06-25-2018, 05:55 PM | #9 |
I'm already stocked on those
06-25-2018, 07:01 PM | #10 |
I should have known that YOU stay well-prepared in that which you do VERY WELL. I guess that my point here is that folks need to remain aware that Fred (barnfind08) really has a massive assortment of NOS Ford parts, some of which just ain't available anywhere else. When ya need a hard-to-find widgit, don't forget to contact Fred to see if he has a few. DD
06-26-2018, 05:15 AM | #11 |
Thanks V8COOPMAN, I am one of those that WAS unaware that barnfind08 has lots of NOS parts. I added him to my parts contact list.
06-26-2018, 04:00 PM | #12 |
Ford fans, it can be done!
After an hour of sweat and busted knuckles from the snap ring refusal to sit still for the brute force approach, I figured a way to make little beast stay put. I drilled a 3/32" hole from the groove into the mounting shaft, at about the 1:00 position. Stuck a pick into the hole to block the snap ring from turning, then drove a filed down little screwdriver under the end of the snap ring. That got it out far enough that I could pull it off with a pair of pliers. Lord knows where it landed after it popped off. I hope I never see it again. When the pedal goes back on, I will use a suitable modern snap ring, or two. |
