Old 10-11-2017, 07:12 PM   #1
vern hodgson
Cool Powder coating
How can you determine if wheels are powder coated or painted?
vern hodgson is offline   Reply With Quote
Old 10-12-2017, 01:03 AM   #2
denniskliesen
denniskliesen's Avatar
Default Re: Powder coating
Powder coat chips and fades or loses it's shine easier then enamel or some of the other coatings.
denniskliesen is offline   Reply With Quote
Old 10-12-2017, 08:00 AM   #3
SeaSlugs
SeaSlugs's Avatar
yea if theres a chip in it anywhere you can look close at the edge of the chip - if it looks like a candy shell over powder its powder coat. Usually powder coat appears thick looking especially around hard bends (like spoke to rim area) and can tell alot of times by just feel - has that kinda plasticy feel and the object temperature doesnt exactly match what the metal temp should be - hard to explain but it like touching a plastic garbage can in the winter vs a metal one - both cold both same temperature the metal one just feels colder.
Paint wise look closely as with all the spokes its bound to have a thin spot or overspray spot.
1929 Model AA - Need long splash aprons!
SeaSlugs is online now   Reply With Quote
Old 10-12-2017, 09:19 AM   #4
Oldbluoval
Inside the rim, I think you can take a wetted rag with a bit of lacquer thinner and lightly rub. Enamel, etc will be effected by the thinner and color will show on rag but powder coat will not. This is a quick litmus test and thinner should not be on either very long. And if the tires are on the wheel you may need to go inside the hub or forget it.
At least the powder coat I have been exposed to (not much as I don't care for it) has worked this way. I will accept corrections!
Oldbluoval is offline   Reply With Quote
Old 10-12-2017, 10:44 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I had my lower water pipe powder coated inside and out, thinking it would give the pipe permanent protection. In ho time at all the antifreeze removed all the powdercoat from the inside, and sent it in strips to the top of the radiator.
I also don't care for powder coating.
Old 10-13-2017, 01:45 AM   #6
vern hodgson
Interesting, I thought powder coating was bomb proof.
Old 10-13-2017, 06:07 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
As with anything, it was 'bomb-proof' until competition began. Then cheaper materials were introduced and corners were cut during the application process in an effort to make it cheaper. In our hobby, I don't see a value when you compare each aspect of it to sprayed urethane.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-13-2017, 07:01 AM   #8
eystein
eystein's Avatar
Brent,
A question about terminology here, as the term urethane is not used over here. What is urethane ? For my understanding, can you name a couple of well known brand names for urethane paint ?
I am using DuPont Centari 500. Is that urethane or is it classified as something else ?
Photo showing color of original early 1930 Cabriolet single-tone Drab Brown dash-grain cowl cardboard wanted
eystein is offline   Reply With Quote
Old 10-13-2017, 07:47 AM   #9
SeaSlugs
SeaSlugs's Avatar
one rock chip and its over, that spec gets wet starts to rust and since its powder underneath the candy shell it holds water and rusts/corrodes underneath the pretty part. Its pretty much plastic powder that is baked onto the part and not actually bonded to the part. Once you get one chip the only fix is to remove all powder coat and redo the part.
Old 10-14-2017, 04:01 AM   #10
vern hodgson
Unhappy Re: Powder coating
That is too bad, I recall a customer years ago pounding two pipes together to show me the durability of powder coating.
Old 10-14-2017, 06:17 AM   #11
BRENT in 10-uh-C
In reality, I can do the same thing with a thin coat of single-stage urethane sprayed over a thin coat of epoxy primer.
BRENT in 10-uh-C
Old 10-15-2017, 12:18 AM   #12
updraught
updraught's Avatar
Originally Posted by eystein View Post
Brent,
A bit confusing all this paint stuff, here is some reading material.
http://www.mtfca.com/discus/messages...tml?1259713203
http://forums.aaca.org/topic/189930-centari-paint/
https://www.hemmings.com/magazine/hc...e/1538643.html
updraught is offline   Reply With Quote
Thread Tools
Display Modes
