07-21-2014, 11:30 PM | #1 |
swaping 3.78 ring and pinion into 4.11 banjo
I have a matched set 3.78 ring and pinion in a banjo that I want to put in my 1935 banjo that presently has 4.11's. The bearing sizes for the pinion are different with the 4.11 being a larger diameter than the pinion bearings in the 3.78. I think this means that the 3.78's are from a 42-46? rear end. I think the splined shafts are the same diameter though. If I get the correct bearings I should be able to put the 3.78's into the 4.11 banjo, shouldn't I? Thank-you,.....Matt in Alameda
07-21-2014, 11:41 PM | #2 |
Re: swaping 3.78 ring and pinion into 4.11 banjo
Matt, what is the spline count on the pinion of the 3.78 gear set vs. the spline count on the pinion of the 4.11 gear set?
07-21-2014, 11:52 PM | #3 |
The 4.11 is 10 splines, the 3.78 is 6 splines.........I want to use a 1940 drive shaft and torque tube ( 6 splines), because it is a LOT cheaper to shorten than a tubular torque tube which I need to do to put my Ford t-170 4 speed over drive tranny in....Matt in Alameda
07-22-2014, 01:22 AM | #4 |
I replaced my 4.11 with a 3.78 out of a 39 car, using a 35 banjo. The bearings I needed were Timken 22166 and the race (cup) was 22325
Hope this helps Dave h |
07-22-2014, 01:32 AM | #5 |
We have put later 3.54 gears onto 35 housings by by using the later centre housing and 35 outer housings and bearings.The inner bearing shoulders on the later CW are exactly the same distance fron centre as the earlier version.6 spline of course. Cheers.
07-22-2014, 03:44 PM | #6 |
07-22-2014, 03:55 PM | #7 | |
07-22-2014, 05:51 PM | #8 |
You can put the later 3.78 gears into an early housing with a bit of machining,
You need to machine the pinion down to fit inside the early housing,machine the bearing area down to the early size,make a spacer for the bearing nuts. And it then will fit in,you then have to alter the driveshaft spline fro 10 to 6 spline. Some one on the earlier barn did a more detailed how to on this, I think bruce lancaster maybe. Lawrie |
Thread Tools | |
Display Modes | |
