01-22-2014, 01:46 PM | #1 |
Oil filter
I posted a while back about the return line on a 39 model motor, had several responses on this including a banjo bolt on the fuel pump stand. I cant find one that will work,but i saw a intake that had a plug on the fuel pump stand,right beside the glass bowl on the fuel pump. I have a aluminum intake that has the same fitting in it. Is it possable to return the oil to the motor on that fitting,thanks
01-22-2014, 03:33 PM | #2 |
Re: Oil filter
I recall your original post as it turned out you were not concerned with authenticity.
So, that being the case, you can return the oil anywhere you'd like. Being returned through a fitting in the valve chamber cover would certainly be a functional method.
01-22-2014, 03:51 PM | #3 |
Re: Oil filter
