Old 07-14-2020, 12:06 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Head Torque Question
In Bratton's catalog, it specifies that the torque on a 5.5 to 1 ratio head should be 65lbs. I have been told to torque to 55 lbs.
Can anyone advise the correct torque for the head nuts on a 5.5 to 1 head???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-14-2020, 01:15 PM   #2
Ruth
Default Re: Head Torque Question
I have always used 55 ft/lbs with no problems. Routinely check mine. Snyder's recommends 55 ft/lb.
Add; I have a 5.5 head.
Old 07-14-2020, 01:58 PM   #3
Big hammer
My engine builder said to torque my 6.0 head 55 ft-lbs initially and re-torque 60 ft-lbs
get a bigger hammer tap done
Old 07-14-2020, 04:35 PM   #4
johnneilson
I have heard many different tales of woe here.
Truth is that both 55 and 65 Ft# are correct.
55 ft# for clean lubricated fastener, 65ft# for dry assembly.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 07-14-2020, 06:35 PM   #5
Bill G
Bill G's Avatar
I think the Ford factory specification was "Good and tight". Maybe "real tight" on a standard head and "Good and tight" on the police heads.
-Bill G
Member of Walla Walla Sweet A's Model A Club
Old 07-14-2020, 06:52 PM   #6
Benson
Benson's Avatar
I do not know about anyone else but I have used 55 foot lbs since 1963 on Police Head for the last 53,000 miles ... works fine.
ADDED: Have used Copper Coat and Victor or Best gaskets.
There is no need for 65 ft lbs ... this only distorts the upper deck of block and might strip out weak stud threads.
Just saying....
Old 07-14-2020, 09:32 PM   #7
Synchro909
Synchro909's Avatar
I always use a sealer with the head gasket so I opt for the lower setting. 55 ftlb is all I have ever used and I've only ever blown one gasket but wasn't head tension that caused that one.
It is no burden to carry a little extra knowledge.
Old 07-15-2020, 05:08 AM   #8
Werner
Werner's Avatar
909, please, what sealer did you use for the very hot head sealing?
Thanks!
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Hercules NSU-Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 07-15-2020, 05:32 AM   #9
Synchro909
Synchro909's Avatar
[QUOTE=Werner;1909240]909, please, what sealer did you use for the very hot head sealing?
Thanks![/QUOTE
Werner, I have used Hylomar but I now have ABRO Copper Gasket Spray. It is an American product. There are several on the market and I'm sure there will be one available in Germany.
