12-23-2018, 04:37 PM | #1 |
Size of seat swivel pin on 1930 2dr sedan
Could someone tell me the od and length of the front seat swivel pins on a 1930, 2dr sedan.
12-24-2018, 01:44 PM | #2 |
Re: Size of seat swivel pin on 1930 2dr sedan
if not looking for points-repros-(Brake Clevis pins will work)Model A vendors sell seat pins.
www.whidbeymodelaclub.com Last edited by Gary WA; 12-24-2018 at 01:49 PM. |
12-24-2018, 05:52 PM | #3 |
Thank you so very much Gary!
12-24-2018, 07:59 PM | #4 |
The brake pin was not correct for the Tudor Sedan, It did not have a cotter pin. The correct pin has a recess for a wire clip. If you want a picture let me know.
12-25-2018, 11:07 AM | #5 |
Please post a picture! For prosperity :-)
12-25-2018, 11:29 AM | #6 |
www.whidbeymodelaclub.com |
12-25-2018, 01:41 PM | #7 |
Mine has nuts and bolts. :-)
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
12-25-2018, 02:04 PM | #8 |
12-26-2018, 12:50 PM | #9 |
I know it is not "correct" but I just put one 3/8" rod all the way across with a cotter pin hole on each end. It is a lot easier to install and remove.
12-26-2018, 04:21 PM | #10 |
I think the hinge pin shown is for the seat back not the mount on the floor. That is why the description call out for use on passenger seat.
