Old 09-30-2016, 10:51 AM   #121
flatheadmurre
flatheadmurre's Avatar
Default Re: Need help from the flathead gurus...? Valve clearance issue
Originally Posted by Mart View Post
I'm a little out of my depth here, but this is an interesting subject. The thing that occurs to me though, is that it is an offset of the cam lobe to the lifter centre that promotes a rotation in the lifter. The radius may be a red herring as far as rotation is concerned. If the cam lobe wiped directly across the centre of the lifter it would not want to rotate. Offset that wipe area and the lifter will receive a little rotational push every time.
Mart.
This i agree with fully !
And valve rotators has nothing to do with lifter rotation, they promote uniform heat, wear and deflection of the valve and helps keep the seat clean from deposits.
So not a bad idee to use them in my book.
The weight difference between rotators and non rotators are 3g so more to be gained from hollow lifters for weight.
And that they should break....they are used with the same design on heavy diesels with lotīs of more springpressure then any race flathead ever is going to see.
Then when it comes to mixing parts...lotīs of ways of doing it...not only one way that is correct.
Most of the time personal taste is what descides....
Old 09-30-2016, 12:19 PM   #122
crazycasey
I think the way this motor WAS set up, it probably would have run pretty good. The valve clearances were all a little off, but the rotator retainers held the spring at a 1.950"-ish height yielding something like 55 lbs on the seat, and the flat bottom lifters wouldn't have likely caused any issue. Now I'be got a much stouter setup, and everything is very well sorted, but I've spent another $500 and I have no idea if it was worth it. Glad for the knowledge though, and I'm already planning my next flathead build.
crazycasey is offline   Reply With Quote
Old 09-30-2016, 12:26 PM   #123
Tim Ayers
Awesome and great attitude. Certainly learned a lot from this thread.
Old 09-30-2016, 12:44 PM   #124
JSeery
JSeery's Avatar
I have a question, have you checked the NOS lifters you just received for length? I remember your original ones were all over the place, are the NOS ones fairly consistent on length?
JSeery is online now   Reply With Quote
Old 10-01-2016, 10:06 AM   #125
crazycasey
No, they were all 1.720" +/- 0.001".
Thread Tools
Display Modes
