03-30-2018, 02:28 AM | #21 |
Re: Sometimes I get tired of it
Milk is good for un seizing an engine that had alloy pistons.
03-30-2018, 04:41 AM | #22 |
03-30-2018, 11:00 AM | #23 |
03-30-2018, 12:00 PM | #24 | |
Wow, these collage student tests (like the atf/acetone and this test) are a big freegin joke. A nut and bolt that has been in salt water for a week, could be takin apart with your fingers. They let these nuts and bolts sit in salt water for a week, boy that is hardly a comparison for Real World Metal, that has rusted together for years, and almost welded together. That is when you need a great penetrating oil. Manufacturers spend lots of time and money testing products that have the BEST chance at penetrating Real Rust, and yes, some are better than others, but I have not seen a product made from acetone and mixed with anything that any manufacturer has put on the market. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
03-30-2018, 03:49 PM | #25 |
Most of these tests are guffaw.
But I can't figure why they do it if they are not selling something ? Anyway on another point. There was a bit of a craze a few years ago on these wrist bands with some miracle metal plug attached. The scam was..... you outstretch your arms and turn and point your straight arm to the furthest point around. THEN you put on the wrist band and do the same, WOW, miraculously you can go another 10 degrees around. It MUST work, that is $60 thankyou very much. I did my own test. In the morning, I put the band on first , then turned, then removed it .... and guess what... I could turn 10 degrees more without it. It was not the wrist band doing anything, it was the pre stretching of the muscles on the first turn. They scammed millions. |
03-30-2018, 04:59 PM | #26 | |||
The fact that your mixture is evaporating instantly leads me to suspect you're not actually experimenting with a 50/50 mix of atf and acetone. Quote:
Where is your test data that qualifies you to discredit the research? How do you think the manufacturers test their products? Probably in a controlled, repeatable environment. What do you suggest? How do you figure? Quote:
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic |
03-30-2018, 05:31 PM | #27 |
Nathan, I've been soaking a Truly Rusty bolt, that is on an old trailer hitch part,
for well over a year in ATF. At first I was mixing acetone with it for a while. The acetone separates from the atf, after a short while, so I had to keep shaking it up, and after doing that for a couple weeks, the acetone was evaporated, so I added more acetone, and keep shaking it up to keep it mixed, after the acetone evaporated again, I have just been letting the Rusty part with the Rusty bolt soak in atf, and as I said, it's been soaking for well over a year. I take it out every now and then, and even with good wrenches, the nut won't budge from the bolt. It has proven to be a big waste of time. If you get a rusty nut or bolt loose with atf/acetone mix, then it WASN'T very rusty. And on a hot day, out in the open air, the acetone evaporates very quickly. .
03-30-2018, 06:08 PM | #28 |
Some people taking part in this thread (which is about people parroting things they have heard without the knowledge to back it up, not just Acetone/ATF mix) could become aggressive or abusive. Keep it nice, guys. Good to see it hasn't gone that way too much yet but.....
There is another oft repeated line out there about overheating. Many say that if the water circulates too quickly, it doesn't spend long enough in the radiator to cool down so the motor gets hot. Well, if it circulates that quickly, it won't be spending enough time in the engine to get hot either. Then there are those who say when water is discharged from the top tank that the pump is moving more than the core can handle so it must be plugged up. Think about that. The only place the pump can get water is from the bottom of the radiator. That water must have already gone through the core from the top tank, thus leaving exactly the same amount of space there for what ever the pump delivers. It is a closed system and only circulates what is in it. Water overflowing the top tank is therefore not caused by the pump being too strong. Grinding impeller vanes is would not be addressing the issue. Some cars used to have a wire coil (like a spring) in the bottom radiator hose to stop it collapsing when the thermostat was still closed and the pump was trying to move more water than it could get. A restricted radiator would cause the same thing and that was a dead give away for a restricted radiator. The Model A has a solid bottom hose so don't have that diagnostic tool. Now, to get a conversation going, I'd like to outline a test I think would prove whether a radiator is restricted on a Model A. From experience, I know there will be some who already disagree with what I have said but I hold the above to be true. I haven't had the need to use this test but it all makes sense to me. I'd like to hear (respectfully) what others think of this: Remove the thermostat if you have one and refill the cooling system. Attach a tube to the drain cock in the bottom hose and submerge the other end in a container of water on the floor under the car. Start the engine and run it at medium revs. Open the drain cock. If the core is blocked, the pump will be trying to move more water than the core can provide so it will suck water from the container on the floor. If the level drops quickly, you have a restricted radiator. The quicker it drops, the worse the restriction. A slow drop might be observed even if the radiator is new so that wouldn't cause for a lot of concern. If the level in the container on the floor rises, your radiator is super good. Give yourself a smiley stamp.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 03-31-2018 at 04:39 PM. |
03-30-2018, 06:53 PM | #29 | |
03-30-2018, 10:05 PM | #30 |
Good discussion. I haven’t had an issue with rusty bolts in years due to starting to use impact drivers. I have an occasional problem with cam out and if it’s really bad I’ll use an easy out. I don’t even use penetrating lubricants anymore.
03-30-2018, 11:57 PM | #31 |
WD-40 does make a penetrating oil for what it's worth.
I know the voices aren't real but damn they have some good ideas! |
03-31-2018, 07:58 AM | #32 |
FWIW, diesel fuel makes a good penetrating oil.
FWIW, I read once, somewhere, that when steel turns to rust it expands to 27 times its original size. No wonder it's so hard to get rusted parts apart.
03-31-2018, 02:55 PM | #33 |
Been using weasel piss professionally for forty years,this is the best Ive seen.. |
04-01-2018, 11:55 AM | #34 |
I liked the plot farmers with the little feet.
04-01-2018, 11:16 PM | #35 |
Adding 'heat' to rusted nuts after using 'concoctions' and then letting sit for a spell greatly improves results (expansion factor).
04-02-2018, 12:03 AM | #36 | |
I’ve thought the same thing. I have a rebuilt engine in my test stand now , and was thinking of a way to stop flow thru the lower hose, to see if the radiator would then overflow as the block was emptied. However your petcock idea is an interesting way to prove the same thing! |
04-02-2018, 01:45 AM | #37 | |
04-02-2018, 06:59 PM | #38 |
Because the overflow is open to the atmosphere, the system isn't a truly closed system. My car and many others have proved that when rust flakes or grease blocks the tops of the radiator tubes, the water pump can, and will, fill the top tank and overflow out the overflow tube. Then things really start cooking!
04-02-2018, 07:29 PM | #39 | |
04-03-2018, 06:31 AM | #40 |
50/50 mix MMO/Acetone or ATF ?? The acetone acts as a surfactant and through capillary action carries the lubricant into the troubled area.
I have had much better luck with a little heat followed by a spritz if water. Not red hot or even close, just warm enough to cause the parts to expand and the water contracts and is drawn in. This some times needs to be repeated numerous times. The water also acts as a temporary lubricant and also dissolves the rust/corrosion. What better product to free up rusted nuts/bolts than the product that made it? A little heat, a little water, a lot of patience. Maybe a surfactant added to the water would be an aid? |
