Old 04-03-2020, 01:16 PM   #1
M2M
M2M's Avatar
Lightbulb 2 degree advance crank gear for model A
Anyone heard of an advanced crank gear? I might be getting my hands on a crank gear with two keyways, one for standard and the other for 2 degrees advanced.
I know Model T guys are using advanced timing gears for improved performance...or so they say.
M2M is offline   Reply With Quote
Old 04-03-2020, 01:23 PM   #2
Benson
Benson's Avatar
Default Re: 2 degree advance crank gear for model A
Bill Stipe sells such a gear for advancing timing...
Benson is offline   Reply With Quote
Old 04-03-2020, 01:29 PM   #3
M2M
M2M's Avatar
Stipe has an advanced cam gear or crank gear? I'm talking about a crank gear.
Old 04-03-2020, 01:47 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Bill Stipes' is an adjustable cam gear. which IMO would be more practical than a fixed crank gear. Adjustable up to 8°. advance or retard.
But if you are getting a 2° crank gear for a good price, I say go for it. May want to degree in your cam to check where you're at?
Old 04-03-2020, 01:55 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yeah, as I recall it was made in the 50's by Winfield (-or maybe it was in the 60s by Bell or Harvey Crane).
As you probably know, advancing the cam will bring in more low-end, so they were probably a good thing back when all you had $$ for was a reground 'B' cam. Stipe has already factored that in for their IB series cams.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-03-2020, 02:00 PM   #6
Benson
Benson's Avatar
Ok sorry ... this one is a camshaft gear
Old 04-03-2020, 03:16 PM   #7
duke36
Would it be helpful for those with a high compression head ? The Stipe's
gear can set advance or retard.
duke36 is offline   Reply With Quote
Old 04-03-2020, 03:17 PM   #8
wmws
Can someone explain what an advanced crank gear is for.
wmws is offline   Reply With Quote
Old 04-03-2020, 03:46 PM   #9
Patrick L.
Patrick L.'s Avatar
Post #5. Advancing valve timing increases low end power/ lower engine speeds. Retarding it helps with top end/ higher RPMs.
Old 04-03-2020, 03:57 PM   #10
wmws
Post 9. Why not do that with the cam gear? Tell us M2M why use the crank gear to advance the timing?
Old 04-03-2020, 04:30 PM   #11
Werner
Werner's Avatar
Hallo!
just turning the camshaft advance has only no more power.
It is better to spread the valve open angle time overlap. But even that only brings more performance / advantages at high RPM.
Concluse: No performance possible.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-03-2020, 06:05 PM   #12
M2M
M2M's Avatar
Question Re: 2 degree advance crank gear for model A
Yes, that's my situation, I can have a new advanced crank gear at a good price...but...(see my comments below)
What would be the result of using a 2 degree crank gear with a Stipe IB330?
I was planning to use a Stipe 330 cam ($450), but since I've come across this gear I wonder if I should regrind my existing cam and save money? Will a reground with a advance crank gear more or less equal a Stipe?
Old 04-03-2020, 06:34 PM   #13
Patrick L.
Patrick L.'s Avatar
You can. Usually the change is made thru the cam gear, but, it can be done either.
Old 04-03-2020, 06:35 PM   #14
Patrick L.
Patrick L.'s Avatar
Originally Posted by Werner View Post
Hallo!
Not true.
Old 04-03-2020, 06:59 PM   #15
johnneilson
At best an opinion
Winfield sold offset pins for the cam gear
If I remember they were 4 or 5 degrees
Honestly in such a detuned motor you would not see much gain
There are other things that make a larger gains
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
Old 04-03-2020, 08:39 PM   #16
40 Deluxe
Originally Posted by johnneilson View Post
At best an opinion
Have you done dyno tests to prove your idea of not much gain? Sometimes small changes such as cam timing can make a big difference. Sometimes big changes only make a small difference! You never know until you try.
Old 04-03-2020, 10:11 PM   #17
johnneilson
40,
no, I haven't tested 2 degrees of timing change, I typically see a difference when making a 3-4 degree change.
I have had 4 degree change make a 10% difference at a specific RPM. That brought the HP up to just under 150 with a siamesed intake port flathead motor.
In all honesty, I have never done a cam dial in on a stock motor, I don't know what the accumulated tolerance would be, maybe Brett has an idea. If the tolerance was +/- 1 degree then a 2 degree change would probably not make much difference.
Just my $0.02, stay safe, John
Old 04-03-2020, 10:33 PM   #18
Jack Shaft
'Its a long way to the top if you want to rock n roll'
if there was a short cut to fast everyone would do it
Jack Shaft is offline   Reply With Quote
Old 04-04-2020, 12:47 PM   #19
Jim Brierley
I doubt if 2* would make enough difference on a stock or mild engine. Stock Model T's have their cams quite retarded compared to A's and all other more modern engines. This was more common in the early days. Stutz did the same thing. Those days engineers were still learning about the new-fangled gasoline engines.
Jim Brierley is offline   Reply With Quote
Old 04-04-2020, 12:55 PM   #20
M2M
M2M's Avatar
Jim. What would be the result of using a 2 degree crank gear with a Stipe IB330
