Old 05-16-2019, 05:09 PM   #1
Woodie1
Woodie1's Avatar
Default Upper Steering Column Bushing
Has anyone found a good material to use in the upper steering column bushing? I think mine should be replaced since I have some wiggle to the steering wheel. Just enough movement to cause an annoying vibration. Thanks.
Woodie1 is offline   Reply With Quote
Old 05-16-2019, 06:35 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Upper Steering Column Bushing
Unless you are building to fine-point status, Snyders carries 3 different types, --two of which are very close to being authentic. You don't mention whether you have a 7 or 2 tooth, but they offer them with the cloth insert in a Nickel plated one and you can use their aluminum one and 'detail' it a tad with a file and fine blasting media and it will look very close to authentic.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-16-2019, 06:55 PM   #3
redmodelt
redmodelt's Avatar
Replacing it may require removal and tear down of the steering column. The pins have to be driven out of the spark and throttle levers on the rods so the rods can come out. Unless it is loose in the tube the bushing may need to be pulled or driven out.
Old 05-16-2019, 08:42 PM   #4
Woodie1
Woodie1's Avatar
It is a 2 tooth. I was hoping to just replace the woven material in the bushing if that were possible.
Old 05-16-2019, 11:38 PM   #5
redmodelt
redmodelt's Avatar
The whole part is the bushing, not just the woven lining. Think most just replace the whole part when they restore the unit. Maybe someone has replaced just the woven part. I suggest you reask the question with WHAT you are looking to do in the title.
Old 05-16-2019, 11:39 PM   #6
1930 coupe
The material in the bushing looks a lot like a wick from a kerosene lamp.
Measure the width of the woven material, and see if you can find a wick the same width. I have not tried this so it may or may not work, but it is the only thing I can think of that might work.
1930 coupe is offline   Reply With Quote
Old 05-17-2019, 11:45 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
I may be wrong but I would think that a lamp wick is made of too soft material to be used for the upper steering bushing . I've never tried replacing the woven material . I just replace the whole bushing and it can be a pain , considering the removal and replacement of the pins in the gas and spark rods
Old 05-17-2019, 12:34 PM   #8
BillCNC
BillCNC's Avatar
I replaced the whole bushing but I was tempted to use a piece of a woven belt cut to fit.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 05-17-2019, 01:42 PM   #9
Purdy Swoft
The woven belt material is pretty tough and should work , depending on the thickness .
Old 05-17-2019, 03:24 PM   #10
quickchange
quickchange's Avatar
pies of frame welting , the thin one might work
quickchange is offline   Reply With Quote
Old 05-17-2019, 05:34 PM   #11
BRENT in 10-uh-C
Mark, I agree, --and I am not sure how to get the woven material into the recess with the steering shaft still installed. If you must take the upper bushing unit out (...along with spark & throttle rods) it kinda seems it would be best to replace the whole unit. Maybe an inside knurling tool might add some life to the worn bushing, but again that sure seems like a lot of work.
BRENT in 10-uh-C
Old 05-17-2019, 06:11 PM   #12
BillCNC
BillCNC's Avatar
That was my only concern also. I wasn't sure if the thickness would make any difference. I believe the woven belt was like .030" thicker.
Does anyone know if that is area/part is critical in measurement?
I do remember my grandmother telling me waaaaay back when, that my grandfather sometimes used the leather tongue from his shoes after long journey's. She said he used them all throughout the car
in an emergency.
Bearings and/or bushing's in a pinch? Might try a leather tongue from an old shoe.
Regards
Bill
