12-10-2019, 02:17 PM | #1 |
Optima 6V battery charge
On a 6V optima redtop battery, what should the testing voltage be on a 100% charged battery?
JB |
12-10-2019, 02:24 PM | #2 |
Re: Optima 6V battery charge
6.3 volts. 2.1 per cell.
12-10-2019, 02:54 PM | #3 |
6.3 here also.
12-10-2019, 03:15 PM | #4 |
My charger shot it up to about 7.0v and still showed charging not complete.
JB |
12-10-2019, 03:49 PM | #5 |
That sounds fine. Right after charging the voltage will be higher. After charging, let it sit for a few hours, then take a reading. Use a quality fully automatic charger not a cheap one with constant amps.
01-05-2020, 09:42 PM | #6 |
JB |
01-05-2020, 09:52 PM | #7 |
What type of charger do you use? Dave/Green Bay
01-05-2020, 09:55 PM | #8 |
It’s a schumacher 6v charger/maintainer.
JB |
01-06-2020, 02:01 PM | #9 |
Most of these smart chargers are too smart for their own good. Like if a battery gets completely discharged, they will indicate failed battery and not even try to start charging. I use an ancient Western Auto trickle charger to get the things started, and then hook up the smart one.
01-06-2020, 05:41 PM | #10 |
Very good point about the "smart" chargers. I've had the same experience.
01-07-2020, 11:55 AM | #11 |
I've had the best luck NOT keeping these batteries on the trickle charger (Battery Tender) 100% of the time. I'll put the charger on for a day or so once every month or so, but leave it at that. I think leaving AGM batteries such as the Optima on chargers 24/7 is bad for them.
I have a 12V Optima in the mustang that still works great... and is dated 02/06 Good Luck
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
01-07-2020, 12:43 PM | #12 |
I have used a "Battery-Tender" on several of my batter's, for many years, including AGM and/or Optama's, never had what I would call a failure. I did have a problem if I left the 'Tender' disconnected to long.
Bill.... 36 5 win cpe |
01-07-2020, 04:03 PM | #13 |
We use the Battery Tender all winter. It keeps our Optima batteries ready for the next drive. Most of our Optimas last years with no problems. Glass Mat batteries require low charging rates to prevent damage.
01-07-2020, 05:06 PM | #14 |
Battery charge table:
01-09-2020, 01:10 PM | #15 |
I have had good results with this one
01-10-2020, 06:10 AM | #16 |
I am going to return the battery I think. I can’t get the battery to hold a charge. It dropped from 6.36 volts to 6.0 volts overnight. I think it has a bad cell.
JB |
01-11-2020, 04:33 PM | #17 |
