Old 10-04-2016, 12:50 AM   #1
V848 Ford
Default crack in block
After fighting to get this block apart and sandblasted and when I magnafluxed it I found a crack in the inlet port in the valve chamber I don't know if it will leak when hot or if it can be fixed whithout welding or not any ideas I don't want to scrap this after work ?
V848 Ford is offline   Reply With Quote
Old 10-04-2016, 01:34 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: crack in block
Stitching.
Old 10-04-2016, 03:34 AM   #3
tbirdtbird
A or B
that will make all the difference
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-04-2016, 04:43 AM   #4
C26Pinelake
I had an A block stitched 5 years ago and I have never had a problem. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-04-2016, 11:17 AM   #5
100IH
Access is everything when stitching a crack. Drilling, tapping inserting. Afterwards, pressure testing and hot Ceramic Seal treatment from Irontite is your insurance if you can find someone with the setup to do it. Step one: let the shop that is locally recommended, view the crack and see what they say. The second option would be furnace welding/brazing and is very much a specialty, not usually available locally. The chosen auto machine shop who says it can't be stitched might know where there is a casting repair facility for the weld job. After a welding repair, the pressure testing is still a must do. Sometimes things do escalate into rocket science. Also, if it comes to casting repair in the oven overnight, the babbitt will be removed.
100IH is offline   Reply With Quote
Old 10-04-2016, 12:46 PM   #6
V848 Ford
It''s a 1929 model A block.
Old 10-04-2016, 01:45 PM   #7
TinCup
TinCup's Avatar
Check out Tod Buttermore's new cast block might be the best solution.
TinCup is offline   Reply With Quote
Old 10-04-2016, 03:46 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Don't trust a CRACKED block, except for a boat ANCHOR!
Captain Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-05-2016, 08:34 AM   #9
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
We successfully repair engines by metal stitching. Those who say it can't be done have never seen it done.
it is a stress free/permanent way of doing crack repair rather than welding or JB weld.
Dealing with engines from the Northeast and around the world, almost every engine has some form of crack repairs needed to make it whole again.
I have enclosed a few pictures showing examples.
http://www.jandm-machine.com/metalStitching.html
J and M Machine is offline   Reply With Quote
Old 10-05-2016, 12:56 PM   #10
Glenn C.
Glenn C.'s Avatar
If you cannot find a perfect replacement block......metal locking is the way to go. I have seen very large stationary engine blocks and other components, that required stitching and metal locking before the various factory machining procedures commenced.
Glenn C. is offline   Reply With Quote
