Old 05-15-2016, 02:24 PM   #1
mrtexas
mrtexas's Avatar
Default 41-48 woodie liftgate
Could someone tell me how the lift gate on a 41-48 woodie stays in place? With these brackets only? No latch on the bottom?
mrtexas is offline   Reply With Quote
Old 05-15-2016, 03:00 PM   #2
Bill
Bill's Avatar
Default Re: 41-48 woodie liftgate
When the liftgate is in the closed down position the sliding brackets point upward. Manually push up on them and they pull the liftgate tight thru a lever action. Then tighten the knurled knobs to secure the tight position. See pic. Bill
Bill is offline   Reply With Quote
Old 05-15-2016, 03:01 PM   #3
trainguy
trainguy's Avatar
That's all that holds them up,they don't work very well.I have been tempted to grind notches in the top of the slot but never got around to it.As they are I never put the gate up,would never stay up when driving.Phil
trainguy is offline   Reply With Quote
Old 05-15-2016, 03:08 PM   #4
woodiejon
Plus all that exhaust coming is great too.
woodiejon is offline   Reply With Quote
Old 05-15-2016, 04:15 PM   #5
mrtexas
mrtexas's Avatar
No way to open from the outside?
Old 05-15-2016, 05:49 PM   #6
trainguy
trainguy's Avatar
Correct,PIA
Old 05-15-2016, 06:06 PM   #7
mrtexas
mrtexas's Avatar
Originally Posted by trainguy View Post
Correct,PIA
I could install a latch like on a 49/51 if I made the frame longer.
Old 05-15-2016, 06:19 PM   #8
trainguy
trainguy's Avatar
In my opinion,it is to rare and valuable a car to modify.
Old 05-15-2016, 07:18 PM   #9
Bill
Bill's Avatar
I have seen an outside latch on a 41/48 wagon mounted in the center lower rail and it is butt ugly! What I did to make access to the liftgate sliders from the outside was to eliminate the rear side window lock and place a small dowel or molding in the felt window channel to keep the window jammed shut like a shortened broomstick handle you would use to secure a patio door. Open your rear doors take the dowels out then you can slide your rear side glass forward from the outside giving you access to the knurled knobs from the outside. Primitive maybe but has worked for me for 35 years...Bill
