02-19-2019, 09:02 AM | #1 |
Bulb number help needed
The bulb in my shift indicator is missing , and i need a replacement.. '51 Fordomatic column
In the diagram ,its Item # 15021 part of Assembly # 14402.. Any help appreciated.. Thanks , Stan |
02-19-2019, 09:37 AM | #2 |
Re: Bulb number help needed
Ford never used the GE part numbers for their bulbs. A person can still locate the GE miniature bulb catalog and go by specs of what you have to fit. It could be a #44 or 47 but a person needs to know the type of attachment and the diameter of the bulb or at least the diameter of where it has to fit. The GE 51 was used a lot so check it out too.
There are bayonet types, screw in types, pin types, and various others. Most of the 6-volt ones are older numbers. GE had a number rating for the diameter of the bulb and that one looks like a G3.5 or T3.25. If it is smaller then in could be a T2.75. Last edited by rotorwrench; 02-19-2019 at 09:55 AM. |
02-19-2019, 10:30 AM | #3 |
There's a guy called the Taillight King online that might be able to help you out.
02-19-2019, 11:19 AM | #4 |
The parts book shows 1cp so like rotorwrench said probably a #51 bulb.
02-19-2019, 11:57 AM | #5 |
Turbo26T:
The bulb is a GE#51 or Sylvania#51 |
02-19-2019, 08:01 PM | #6 |
Stan |
