Old 11-11-2018, 03:54 PM   #1
ryanheacox
ryanheacox's Avatar
Default Strange timing behavior
Just took the A out for the first time up and down the road. Stopped to see the a neighbor and heard it start to slow down and eventually die. Couldn't get it back going and ended up pop starting it. Seemed to only fire with the spark lever pulled down. Died again pulling into the driveway and had another hard time getting it going.
Attached is a video link. Seems that just the act of moving the lever keeps it going which confuses me.
Timed it so the points open about two notches down and the point gap is set at .020. Points are also third party NOS.
https://www.youtube.com/watch?v=4I8ifqvupxU
Old 11-11-2018, 04:33 PM   #2
wmws
Default Re: Strange timing behavior
You might have a bad wire between the distributor plates shorting out.
wmws is offline   Reply With Quote
Old 11-11-2018, 04:34 PM   #3
Jacksonlll
Jacksonlll's Avatar
My first guess is that something must be loose. If it was a make-break short, it should backfire some of the times. Loose cam??? loose point plate??? water in the fuel???
Good luck.
Old 11-11-2018, 05:01 PM   #4
arnhemmer
Put lever in full retard and place pin in timing gear dimple (DTC) and recheck the distributor rotor position. Cam might have come loose. Idling in full advance when everything is normal is not good for the motor. It actually should stumble due to being too far advanced when idling.
arnhemmer is offline   Reply With Quote
Old 11-11-2018, 05:54 PM   #5
ryanheacox
ryanheacox's Avatar
Well as far as I can tell, the terminal on the lower plate wire that attaches to the points was intermittently contacting the spring and grounding out. I noted that the old plate that came out had the flag terminal on the wire bent at a 90 and the new one was flat. I didn't think anything of it at the time but I knew it would be very close to the spring.
Timing was right were I had it and after bending the flag terminal it fired up and had no problems. Will have to drive it up and down the road tomorrow to make sure.
Old 11-11-2018, 06:11 PM   #6
Mike Peters
Mike Peters's Avatar
You fixed it. Yeah, the wire part of the flag terminal needs to bent down or it will contact the distributor body. Feels good, doesn't it?
Mike Peters is offline   Reply With Quote
Old 11-11-2018, 06:19 PM   #7
Gary WA
Gary WA's Avatar
Walter agrees good fix!
www.whidbeymodelaclub.com
Old 11-11-2018, 06:20 PM   #8
ryanheacox
ryanheacox's Avatar
It is a really good feeling. Now on to the other minor problems.
Old 11-11-2018, 07:35 PM   #9
Bob C
Here is a picture Marco posted of the flag terminal.
Bob
Old 11-11-2018, 07:35 PM   #10
Dick Steinkamp
Dick Steinkamp's Avatar
Originally Posted by ryanheacox View Post
...ended up pop starting it...
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 11-11-2018, 08:21 PM   #11
ryanheacox
ryanheacox's Avatar
Bob, thats what mine looks like... now
Dick, we push started it. We had a nice long steep driveway.
Old 11-11-2018, 08:54 PM   #12
Dick Steinkamp
Thanks, Ryan. I've never heard the term "pop start"...but then I've lead a very sheltered life.
Old 11-12-2018, 10:18 AM   #13
Big hammer
When I was 16, I was pushing and starting my A way to much ! You don't need much of a rolling speed, a little hard on second gear grinding the gears. After school one day it wouldn't start, got some guys to push and I put it in second gear, they pushed and it started when in a arms length :-)
get a bigger hammer tap done
Old 11-12-2018, 11:04 AM   #14
ryanheacox
ryanheacox's Avatar
Takes a little bit longer when you aren't getting spark
Old 11-13-2018, 02:35 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
Comes from "popping" the clutch while the car is in gear and rolling.
Old 11-16-2018, 11:48 AM   #16
old31
It also takes a little bit longer when your 66 vs 16!
old31 is offline   Reply With Quote
