08-02-2011, 12:32 PM | #1 |
Model B Carburetor
I rebuilt and installed a Model B carburetor on my Model A. It runs at a higher throttle setting but will not idle. Even then it dies when I retard the spark. Apparently the idle circuit is still plugged or not working. This used B carb must have layed around many years someplace as it was badly rusted and corroded inside. With lots of bead blasting, probeing, and acid cleaning, much gunk came out.
There must be an internal passage still plugged in the idle circuit? Is there anywhere where I can get a carb circuit diagram of the Model B-2 carb? Thanks, John |
08-02-2011, 12:58 PM | #2 |
Re: Model B Carburetor
John,
The 1932 Ford Service Bulletins contain such a diagram. They are available in inexpensive reproduction form. |
08-02-2011, 03:37 PM | #3 |
The throttle plate when closed on the inside should have a hole next to it that is the idle circuit. should have a brass screw into it farther up . follow all these passages and run a thin wire through them.and compressed air
08-03-2011, 01:31 AM | #4 |
I recently went through this same problem with a couple of B carbs that I rebuilt with China carb kids purchased from Mac's Auto Parts. None of the float bowl Jets were the proper sizes. I re-installed the original Zenith jets and the B carbs now run proper at all speeds without having to adjust anything with the changing rpms on the road. I checked the jet sizes using my oxy/act tip cleaners. A wrong jet size makes a big difference on how well the carb will work.
03-31-2014, 06:47 AM | #5 |
